Cam Question. Which springs?
Old Aug 2, 2006 | 04:15 PM
NotthisSS's Avatar
Default Cam Question. Which springs?
I have the TSP 233/239 .601/.603 lsa112 cam. what springs will i need to run with this. and will it be fine on the stock engine?
Old Aug 2, 2006 | 05:05 PM
fguy1998's Avatar
i've got the same cam and they recommend dual springs, i went with the prc's from tsp they are good up to .650 lift.
Old Aug 2, 2006 | 05:41 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Dual springs are recommended but you can get by just fine running some shimmed 918's.
Old Aug 2, 2006 | 06:20 PM
zo6vetteman2003's Avatar
I agree, 918's will be just out of spec., but they will work without drama. Also, valvefloat will not be an issue above 6000rpm with the 918's, but you will have no insurance against dropping a valve on a broken spring. Many here would not take the chance.
