what HEADS to buy?
Old Aug 3, 2006 | 10:41 AM
STANG KILLA SS 2's Avatar
Default what HEADS to buy?
ive got a pretty decent setup. i feel my heads (and headers) are holding me back. i hit 432, but down at 5700!!! drops off bad after that. just not enough air. heads i have now are 4.8L with a stage 2 hand port, stage one done by AMS i believe, then stage 2 done by trevor johnson. stock valves.
what do you guys recomend? its gonna stay stock cubes, and shoot 200-250 on her. trying to build a all out stock cube monster. keeping the current cam probly for now. would also like a small chamber to keep the compression up. im running exactly 11.0:1 right now. i know i wont be able to keep that (58cc) but i dont want to loose too much.
what heads do you guys recomend?
mods
LME Forged 347*Wiseco –2cc Forged Nitrous Pistons*Callies Forged Rods*MJ2 Cam(232/240 .607/.608 112)*Comp Cams Hardened Push Rods*Isky Racing Valve Springs*Isky Racing Titanium Retainers*Stage 2 4.8L Heads*Ported F.A.S.T. LSX 90mm Intake*F.A.S.T. 90mm Throttle Body*Custom Tuning by Mike Dietzes*K & N FIPK*SLP 85mm MAF*SLP Long Tube Headers*SLP Off-Road Y-Pipe*Dynomax Bullet Muffler*Rear O2 Sims*NOS 5177 Nitrous Kit*CAGS Delete*Moser 12 Bolt Rear End*33 Spline Axles*Eaton Posi Unit*Richmond 4.10 Gears*Polyurethane Motor, Tranny & Sway Bar Mounts* BMR Torque Arm*BMR DS Loop*EGR Delete*Taylor 10.4 mm Plug Wires*A.I.R. Delete*RAM Powergrip HD Clutch*LS6 Master Cylinder*LS6 Slave Cylinder*Vented & Slotted Rotors*Hawk Brake Pads
Old Aug 3, 2006 | 11:53 AM
Joel_SS's Avatar
Use the search button you will have enoght opinions to keep you reading for days. and call head vendors
Old Aug 3, 2006 | 12:04 PM
2000TransAmWS6's Avatar
i'm pretty sure that the headers are not holding you back. the SLP headers flow very well, and the short collector promotes better power at high RPMs. most people just don't like SLP headers because they hang so low to the ground, even with stock ride height.
if you get some heads that have a better intake runner design (ie LS6 style heads, or AFRs, etc.), i'm sure that would help you out. larger valves would also help out alot too.
do you know the flow numbers on the heads that you have now?
Old Aug 3, 2006 | 12:10 PM
777's Avatar
777
How can you have a stage 2 head with stock valves? Anyhow IIRC the SLP headers don't flow well at all. I remember seeing something like a 20+rwhp gain on a cammed car switching to kooks or qtp (can't remember).
Old Aug 3, 2006 | 02:01 PM
no dont have any flow numbers.
well thats what i got let down on. they were SUPPOSED to have 2.02/1.60s... found out they didnt just a "stage 2" port. life lesson learned.
yeah i know the SLPs are crap ive seen TOO many slp to XXX header swaps gain 20+ hp.
what do you guys recomend for my situation a all out stock cube juice setup?
Old Aug 3, 2006 | 03:02 PM
King James's Avatar
AFR's and QTP's
Old Aug 3, 2006 | 03:35 PM
afrs what size? 205, 225, 245? (not sure if the 245 are out)
Old Aug 3, 2006 | 03:43 PM
slow trap's Avatar
if you are in the 43x range right now with the slp headers i would try either the kooks or qtp 1 7/8 since you plan on spraying 200-250 and redyno-tune it and go from there .you willl probably be in the 45x range which is decent numbers.it seems your heads flow well enough,to me anyway.
Old Aug 3, 2006 | 03:53 PM
777's Avatar
777
AFR 205's milled (I'd really talk to Tony to see what he recomends, just give him your goals-you might even need the 225's with that big of a shot) and a set of 1-3/4" HVMC QTP headers. You should have no problem hitting over 450rwhp even on the nitrous tune.
Old Aug 3, 2006 | 04:36 PM
The1N_only's Avatar
My vote would be ETP's 225 heads and have them CNC the chamber to the size you want with kooks 1 3/4 stepped to 1 7/8 w/hvmc
Old Aug 7, 2006 | 09:27 AM
can they mill them before there shipped to me? or is that something i need to have done after i get them?
Old Aug 7, 2006 | 09:52 AM
erikthegoalie's Avatar
they can mill em im sure
Old Aug 7, 2006 | 12:36 PM
V6 Bird's Avatar
Cory, Ive already told you the header to buy...The stepped 1 3/4 to 1 7/8 E-brocks with the slip on collectors. For the price, they simply can NOT be beat. You dont have to trim the K- memmber to get them to fit like you do with the KOOKS stuff...Heads are all up to you. Ive yet to see any good posts so far to help you though...
Old Aug 7, 2006 | 05:38 PM
The1N_only's Avatar
Cory... isnt 5800 where it fell on its face before the new short block heads and intake?
