quick question before i instill my cam
yes you would b ok.. but think about it do you really want to have to take the pulley and the cover off again.. you already have everything off why not change it.. it doesnt cost that much anyways. just my. .02
Have some patience. Order the part and replace it. You won't know when it's about to go. It'll just crap out on ya.
We went ahead and pulled the oil pump off anyway. I didn't change the pump, just the timing chain. I dropped the pickup bolt a couple times, but we got it with the pen magnet without any trouble. It took about 10 minutes to get the bolt back in place.
I did read a good suggestion at one point for this. Someone said they used a piece of fishing line tied around the bolt while trying to get it in there. This way it couldn't fall to far down into the oil pan. After it is threaded, you can cut the fishing line off the bolt (making sure to get it all out of there) and thread it the rest of the way in.
If I had it to do over... I'm not sure if I'd try it or not. It wasn't too tough for me, but I felt like I just got lucky.
Like gauge suggested, I used dental floss to keep from dropping the bolt down the pan.
Sorry to take things personally and get off topic.
Anyway, 2gfirehawk, you dont need to do the pump and chain now. While if you plan on doing it in the future, it would be beneficial to do it now since your in the area. but plenty of people have run the stock ls1 pump and chain with their cam. I believe it was limited to the 98's that had the faulty oil pump that would potentially stick open, but those failures probably arent as common as people make them out to be.
