gmpp asa
Old Aug 5, 2006 | 05:57 PM
Charlie@LsXperts's Avatar
Default gmpp asa
does this gmpp cam really have this tiny amount of lift? its the gmpp asa its like 228/234 .525 .525 110lsa
Old Aug 5, 2006 | 10:02 PM
RiceKilla's Avatar
http://www.smokemup.com/tech/ls1.php
Yep, it does, no reason why GM would lie about the lift. Good cam if you have access to a tuner, many state that it has one of the best torque curves they have ever seen.
I am in the market for one.
Old Aug 6, 2006 | 01:47 PM
hmm..... strange
Old Aug 6, 2006 | 02:47 PM
ringram's Avatar
Not really, look at the LSA and duration. That mother is going to have a good amount of overlap which serves to scavenge a nice lung full of intake charge.
I think I read a Vizard article stating exhaust overlap can give up to 5x more induction pressure (-ve) than the basic intake stroke. Thats going to add to your torque right there.
Old Aug 6, 2006 | 04:31 PM
Louis's Avatar
It was used in conjunction with the Hotcam cam package, which utilized the same spring that was in the 2001 Z06s, the Blue spring, or I should say, the 01 Zs used the hotcam spring
Old Aug 6, 2006 | 04:57 PM
s346k's Avatar
i thought the asa cam was 226/236?
Old Aug 6, 2006 | 05:17 PM
00454sscamaro's Avatar
says 226/236 in my book. so i second^
Old Aug 6, 2006 | 06:27 PM
2000RedZ's Avatar
It is 226/236 trust me
Old Aug 7, 2006 | 09:30 AM
hmmm interesting... im thinkin of using that cam
Old Aug 7, 2006 | 03:59 PM
jmm98LS1's Avatar
Great cam with stellar torque curve.....sounds incredible too, I get compliments everwhere I go.
Old Aug 8, 2006 | 07:41 PM
youre the whole reason i posted this jimm98, how many miles on your car? also did that cam throw a code???? cause the cam im runnin now does not throw any codes
Old Aug 8, 2006 | 09:18 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Since your car is an auto did you have an major issues tuning it?
Old Aug 9, 2006 | 09:04 AM
jmm98LS1's Avatar
Car has about 65k miles on it. The only code thrown solely from the cam was multiple random misfire, and that's from the nasty idle. Easily taken care of with tuning.....this cam will barely run on the stock tune, but it won't drive. Absolutely have to tune it.
Didn't have any major issues at all, just took time--probably a couple months before I had it where I wanted it. I did have a little trouble with the idle using the MAF, so I now run a closed loop speed density tune. I used HPTuners and just did a little at a time until it was perfect. It's not my daily driver so I didn't rush anything.
Old Aug 9, 2006 | 12:00 PM
jub jub's Avatar
Nice thing about that came besides the flat torque curve is, you never have to worry about changing springs. A decent set of springs should easily last 100k or more.
Old Aug 9, 2006 | 03:57 PM
70 LS1's Avatar
Conversion master
At the time that cam came out, there were no aftermarket cams available yet and it was considered big lift.
