Missing after heads and cam.....need help
Old Aug 6, 2006 | 03:27 PM
Formula_Power's Avatar
Default Missing after heads and cam.....need help
I just got done with my ls1 heads cam swap and i looked at my misfires and i am showing a miss on every cylinder but not a dea mis just hear and there...i have hypertech tune on my car right now but nothing yet for the heads and cam...the cam is a 230/236 571lift cam...could i just need a tune or is it more serious??
everything looks good...all wires on and spark plugs tight
thanks
Dustin
Old Aug 6, 2006 | 04:36 PM
Zymosis's Avatar
As long as you have checked the obvious, a random misfire code can happen with a cam. I would dump the hypertech tune and get a real dyno tune.
Old Aug 6, 2006 | 06:10 PM
tkz28's Avatar
try setting the hypertech back to stock because all those things do is cause trouble
Old Aug 7, 2006 | 04:21 PM
i set it back to stock tunning and still have a miss on all cylinders
Old Aug 7, 2006 | 08:35 PM
just1news6's Avatar
i say tune asap could be a timing issue
Old Aug 7, 2006 | 09:27 PM
shouldaboughttheZ's Avatar
get a tune
Old Aug 7, 2006 | 09:30 PM
Black FormulaLs1's Avatar
DEF GET A TUNE.. Carolina Auto Masters is where i am going when mine is put back together
Old Aug 8, 2006 | 08:09 PM
has anyone else had a problem with bad missing after a head and cam install??
I am also not able to rev it up past about 4300 rpms....even at full throttle...it's like it's just not getting all the air and fuel it needs...anyone ever seen this be4??
Old Aug 8, 2006 | 08:18 PM
waterbug1999's Avatar
By miss you mean like backfire?
I had one side of my coil pack wire harness switched 180 degres out of sink.
Old Aug 8, 2006 | 10:06 PM
no i have not had a backfiring problem...but the engine missing badly...the whole motor will shake....i guess there is a chance i could have mine on backwards as well i will have to double check that
thanks
Dustin
Old Aug 8, 2006 | 10:11 PM
Well, if its not backfiring then I dont think thats your problem. Mine was backfiring bad so I turned it off and then thought.. hhmmm, wonder if the harness is backwards. And sure enough it was and it purred like a cammed beast!
So your saying you get "missfire" on all 8 cylinders?
I know on my 04 Z71 I had a bad O2 sensor on one side wich caused the motor/truck to sputter and shake. Technically, it was sensing lean so it would throw alot of gas in that side of the motor. Had it scanned it said "misfire".. Just a thought.
Old Aug 9, 2006 | 02:28 AM
1sick'98WS6's Avatar
I have the same problem, my guess is the comp r lifters though..... too long of pushrods. i dont know what my problem is
Old Aug 9, 2006 | 09:56 AM
yes i am saying that there is a mis on all 8 cylinders....no real dead spot just a random miss ....also the car won;t rev past about 4500 rpms
Old Aug 9, 2006 | 06:17 PM
Well, I wouldnt keep trying to push it either. But, I am stumped.
Old Aug 9, 2006 | 06:57 PM
oange ss's Avatar
you need to get the misfire tables tuned..even just a big cam swap with throw a misfire code
Old Aug 10, 2006 | 08:18 AM
Yea I am starting to think it's got to be the tune because i have double checked almost everything and found nothing...i just didn;t think it would run so aweful without a tune....i was faster when i was stock
thanks
Dustin
