New Goodies Installed :)......
Old Aug 7, 2006 | 01:25 AM
Demonicbird00's Avatar
Default New Goodies Installed :)......
b4 i get into it. found a few things that were bad in my motor.... the pass side head gasket was rusted, in turn leaking some coolant,a lifter in cyl.7 was gouged out in 2 spots causing it to scar the cam. and my springs were shot. i could compress them w/ my hand. and lastly pass side head was warped .012 and driver side was warped .009 so i had them milled to be true again.
ok so what i had installed is as follows,
Comp Cam 236/236 .602/.602 114+2
ls2 timing chain
ls7 lifters
ls6 oil pump
comp dual springs
titanium retainers
SVO 30# injectors
and a base tune by Chummmma to get me around tull Tues when i get dyno tuned.
i had my friend joe prince install everything, and went together very smooth, no snags along the way other then this dam weather.
-brandon
Old Aug 7, 2006 | 04:08 AM
DarknessC5's Avatar
Sweet.. be sure to share the numbers when get them... You have a part of all LSx engines installed now... lol ls1, ls2, ls6, ls7..
Old Aug 7, 2006 | 08:31 AM
shouldaboughttheZ's Avatar
keep us informed on the numbers. looks to be a nice set up
Old Aug 7, 2006 | 06:23 PM
will do.... as stated im headed to the dyno tommorrow for a tune then ill get the graph posted w/ numbers.
-brandon
Old Aug 7, 2006 | 07:20 PM
01ls1lover's Avatar
What about the lifter???
Old Aug 7, 2006 | 07:42 PM
what about it? it was gouged out in 2 spots causing it to scar the stock cam.
Old Aug 7, 2006 | 08:49 PM
01ls1lover's Avatar
So its not gonna hurt the new cam??
Old Aug 7, 2006 | 11:13 PM
no i replaced the lifters w/ new ls7 lifters
ls2 timing chain
ls7 lifters
ls6 oil pump
comp dual springs
titanium retainers
SVO 30# injectors
