Its All Finally Installed!!!!
Old Aug 26, 2006 | 12:10 PM
slimcracka's Avatar
whats the block have to do with power?
Old Aug 26, 2006 | 12:31 PM
04LS1GTO's Avatar
where did you buy that cam from?
Old Aug 26, 2006 | 02:12 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Originally Posted by xxtheonlyxx
Can someone with a similar setup give me a rwhp estimate before I hit the dyno??
Congrats on getting it all together...
An auto with a 3K+ verter is not the most chassis dyno friendly....as in no "hero" numbers when you roll it.
I would expect around 425-430 RWHP with around 390 TQ. Obviously hinges on who's dyno and type, the tune, and of course the install being optimized as well (cam degreed, correct valetrain geometry, etc.)
Let us know how you make out...
Also, those figures assume about an 11 to 1 build or slightly higher...
Tony
Old Aug 26, 2006 | 02:51 PM
allngn_c5's Avatar
Originally Posted by 1stz06
My set-up is almost identical to yours. AFR 205's milled .0020, 228/232 588/592 110+1 LSA, fast 90/ LS2 TB. I put down 440RWHP and 400 RWTQ (M6) WITHOUT an underdrive pulley or degreeing my cam. Plus, I have some crappy headers (TPIS) and that is more than likely why my TQ numbers are low. Getting these things corrected and Mamo velocity porting my intake, shooting for 455RWHP on stock LS6 shortblock.
Good Stuff.......impressive set-up!!!
Call up LG Motorsports and you can get some really good Torque increase over those TPIS. My question is why would you get TPIS when you are so close to LG ?
Old Aug 31, 2006 | 01:45 AM
xxtheonlyxx's Avatar
the cam is a custom grind comp cam with hr lobes. Just got the tuning done, and put et streets on it. I have a legit 11 second car. I'm hoping to get to the track soon.
Old Aug 31, 2006 | 09:42 AM
dalejr8ls1's Avatar
I have a similar setup, except Darts and slightly smaller cam, I pulled 440/408. Definatly get some SVO 30's or something, with all those improvments for better air flow you need better fuel flow to match that, and your stock ones will be maxed out.
Old Aug 31, 2006 | 11:39 AM
quiet_storm98's Avatar
i was about to say the same thing...the block has nothing to do with power unless you are talking about a stroker which in that case you would need to use a different heads and cam set up to see a decent improvement
Old Sep 1, 2006 | 07:36 AM
Yeah, my A4 took about 20rwhp from me. I went with 42# injectors so when I upgrade my rails, and add some more mods I can just turn them up.
Old Sep 1, 2006 | 10:22 AM
sickws698's Avatar
nice setup
Old Sep 1, 2006 | 12:24 PM
Bill Bowling's Avatar
I made 401HP and 374TQ with stock heads and all bolt ons (TC Unlocked). What do you think I can make with AFR 205's?
Bill
Old Sep 1, 2006 | 11:01 PM
Bill
I would say at least 430rwhp/390rwtq. With a manual you could pull off up tp 460 with a good tune. I'm going to get a 150 shot to take me over 500.
Old Sep 1, 2006 | 11:53 PM
  #32
RoastEmSS's Avatar
congrats
Old Sep 2, 2006 | 12:47 AM
  #33
The PAT WS6's Avatar
damn buddy ! i bet it felt like a totally differnet car then your used to
Old Sep 2, 2006 | 08:58 AM
  #34
It was crazy the first time I floored it. It felt like I was going to fly in the back seat.
