May have the record for oil consumption...what to do next?
I have already installed the LS-6 valley cover, and installed a catch can, which is only catching a few drops of oil. I also did a compression test, and it is right where it should be. It also runs strong, running a 13.2 @110 with just a lid. I pulled the spark plugs and, besides a bit of a lean condition, they look good with no oil on them. There is noticeable smoke under heavy acceleration.
Anyone have any ideas? The only think i can think of is the rings, but would it still pass a compression test with flying colors?
1 quart every 300 miles. Compression test was not too far off but the leak down test sucked. over 20 % on a few cylinders. I think oil gets on the o2s and the computer starts dumping fuel and helps kill the rings. Domino effect.
John
Bad rings will smoke all the time. Or you will get puffs of air out of your oil fill cap.
Don't feel bad, I use about 2 quarts driving from Lauderdale to Orlando...210 miles. And my heads just got redone. My rings are trashed.
John
My bumper gets black in 3 days right above the pipes. BLACK!
Now if it was buring it, yeah I can agree with you that it would leave a film on the back bumper not spots.
John
John
The bottom of the car does have some oil on it, but when it is sitting in the garage, and I only take this car out on the weekends, there is maybe one or two *small* drops underneath it on the floor. However, the rear diff cover is leaking fluid. Could this be it?
