400+ci
Old Aug 7, 2006 | 09:46 PM
RA4VV's Avatar
Default 400+ci
can i use a production iron truck block with a aftermarket 4.00 stroke crankto get at least420-427ci do i replace the sleeves?is this possible or do i need too look into the ls2-ls7 stuff i would rather stay with the iron block. fill it with blockfill if need be.plans are to build a 420+ci ls1 with a sheetmetal intake & carb(dominator)with some 350+cfm heads.fogger & a plate...
Old Aug 7, 2006 | 10:14 PM
JakeFusion's Avatar
Super Hulk Smash
Can't resleeve an iron block, but you can bore it out to 4.060" if it's sonically checked and verified for such an overbore. Usually 4.03" is the norm and sometimes a 4.04" can be had without much trouble. Here is a list of possibilities with a couple of overbores and a 4.100" or 4.125" crank.
4.03" x 4.100" = 418cid
4.03" x 4.125" = 421cid
4.04" x 4.100" = 420cid
4.04" x 4.125" = 423cid
4.06" x 4.100" = 424cid
4.06" x 4.125" = 427cid
Old Aug 7, 2006 | 10:18 PM
Daniel_z28's Avatar
so then a 4.1" crank will fit the iron block?
Old Aug 7, 2006 | 10:34 PM
JakeFusion's Avatar
Super Hulk Smash
The iron block, if clearanced properly, can take the 4.125" crank.
Old Aug 8, 2006 | 07:18 AM
RA4VV's Avatar
i see, this helps out alot. ive built alot of engines small & bigblock chevy's & several pontiac's all that made good power just have never messed with the new stuff (LS1,LS2&LS7)but im learning thanks for the info.
