New Heads! (Need a cam!)
I know the milling is going to set me back and was wondering what is the biggest, roudiest, loudest, and powerful cam I can install without flycutting? I was looking at the Torquer V2 and was hoping that would fit.
Would thicker gaskets help? I wish they weren't milled really. Any help would be great.
EDIT: If the TV2 doesn't fit, what about the TSP 224/581/112? Also, will I need shorted pushrods?
What is the car used for? Drag racing is more immune to low RPM power loss from lack of compresson so if you want the dyno numbers get the TQ'er 2 and run lower compression. If you want more area under the curve then optimize compression and run what fits: 226/230 or 228/232 XER cams. Personally I think you are better off with the smaller cam optimized.
The cam suggested to you will lope fine and you will need less static CR to acheive a good dcr. Even a 224/228 xer would shake at 800rpm and sound better than the stocker. I had that cam too and it lopes fine. You could save a lot of time if you just lower your idle to get the car to have a mean cam sound with the shake. All cams (even the stocker) lope but the idle speed is shifter higher depending on overlap. Just for laughs lower your idle 150-200 rpm and see what I mean.
Good luck with the car.
I had 224/230 114+2 XER
228/232 114+0 XER
Both shake, sound awesome, and both need a bump in compression. They fit safely and you will be happy either way. I think the cam suggested by PredZ is the way to go since on a college budget it will still have great DCR without going into the heads right away (but you will need good springs).
Good luck with it.
I am guessing that would be a custom order and could order it from TSP?
Also, the comp cams 918 springs would work fine?
Last thing: pushrods. What size would I need?
https://ls1tech.com/forums/showthrea...18#post5355918
