PRC heads or Patriot heads?
#1. PRC stg 2.5 LS6 CNC'd heads with 2.04/1.57 valves and PRC double valve springs, milled for increased compression(11.25 area).
or
#2. Patriot CNC'd 243 castings with 2.00/1.55 valves, 227 runners, and Patriot Gold spring kit. Flow in the 300 range.
If you plan on the TV2 112 then it won't fit with 2.04 valves.
Either get PRC Stage 1 or PP stage 1 (both are 64 cc), difference is the CNC program.
PRC is ~ 235 cc intake runners and PP is ~ 227 (both have stock valves 2.00/1.55)
Either is a good choice. The PP would probably make a little more trq below the curve due to the smaller runners.
The PRC will maybe make a couple more peak Hp.
I've never seen any test on that, this is just speculation.
PRC heads flow more than patriots and our bench is a little stingy, we have had customers independently test the PRC heads and go way more flow than what we advertise. Personally I wouldn't think twice about going with PRC heads. Also we set up each customer's heads with their desired cam in mind, so if you do go MS4, MS3....etc, we can sink the valve and shim the spring for added P/V clearance, also allowing you to run a thinner gasket and bump up compression.
If you want more info on the heads just let me know!!
Zach
Zach
You sink the valves, you loose flow, not recommended unless absolutely necessary.
IMO unless you go with aftermarket valve seats, 2.02 should be maximum.
(because come to find out that stock seats are 2.02, so 2.04 valves will not seat "properly", meaning you won't really benefit from them over 2.02s)
Now don't get me wrong, 2.04 will work, but there is no real gain in doing so.
TV2 112 will have less than .080 intake clearance on a 2.04 valve, not recommended for street.
Just remember that not all motors are created equal, and piston deck height varies from .005 to .01 out of hole (average around .007/.008), so why risk it?
From my personal experience on the TV2 get the 112 and whatever head you decide, stick with stock valves, they are plenty.
Sinking the valve does not lose flow unless your doing something extreme, the amount it would take to get something close to fit would not lose any flow at all.
I'm talking about a 112LSA,
What was your average clearance value, intake/exhaust?
and I've not said that you need to sink them, but out of curiosity, how do you sink 2.04 valves on a 2.02 seat?
We produce a quality product that performs as we say it will. Flow numbers are not inflated or made up. We send a flow sheet with every set of heads. This sheet is specific to that set of heads.
Soon the trend of high quality at a reasonable price will continue with our Predator heads. They have taken longer than we would have liked, but it takes time to produce a quality product from scratch.
Zach
Zach
NO ANSWER???
If I'm talking nonesense please correct me, for it is better to recognize ones fault then to live in darkness.
Adding to my questions is what ICLs are clearing the 2.04, and when clearing, by what margin ??
This is good education so we know where we stand in our purchases.
(When I purchased the TV2, I requested that my margins be at least .080 int and .100 exhaust, the answer I got was only the 113+0 will give those, and that 112 while still "fitting" would be tighter than that)
So could you verify the clearances at 112+0, 112+2 and 112+4 please.
This is on a stage 2.5 (2.04/1.57)
You can cut up to a 2.04" valve job in a stock seat. Therefore any valve up to that size can be put into the stock seat. With our cnc valve job machine we can instantly adjust the valvejob size for bigger valves or for different valve depths. If you design a port for the valve set to a certain depth then you can easily keep the valve at that depth. Installing a 2.04" intake valve with a 2" installed height would definately hurt p/v pretty bad, but sinking them .015" or so helps to offset a lot of the bigger valve. We've spent hundreds of hours testing different valve sizes, depths, and angles. Rest assured that if I say we can sink the valve a little bit without compromising flow, then it won't.
The torquer 2 has been installed many times with several competitors cylinder heads that have 2.02 & 2.055 valves. We've built Stg 2.5 heads countless times to work with the T2. If anyone has any questions or concerns call the shop & talk with Jason, he's built enough different valve/depth configurations to make you go CRAZY!!
What a lot of guys don't understand is we can instantly change ANY length or angle on our valve job. VERY VERY few shops in the entire country have this ability. When you can have complete adjustability in your valve job, you can make changes to adapt to different depths & different flow characteristics.
