Please Help!!! Block Specs Needed!!
Old Aug 17, 2006 | 11:07 PM
camSSaro's Avatar
Default Please Help!!! Block Specs Needed!!
I am in desperate need of the cam journal specifications on the ls1 blocks. There is a possibility that mine have been ruined due to a cam bearing coming completely detached from the block while running. All information regarding this will be greatly appreciated. Any machining guru's out there?
P.S I have tried a chevrolet dealership and have got very little cooperation from them
thanks again, Corey
Old Aug 18, 2006 | 12:08 PM
mmmchickenboy's Avatar
have you tried an auto machine shop? they usually have access to that information.
Old Aug 18, 2006 | 12:25 PM
jrp's Avatar
jrp
SN95 Director
https://ls1tech.com/forums/showpost....6&postcount=27
Slo_240sx's Avatar
Camshaft bearing journal run out should not exceed .025mm (.0010)
Camshaft bearing journal Diameter- 54.99 - 55.04mm (2.164 -2.166in)
If camshaft is less than spec it needs to be should be replaced.
-Alex
Old Aug 18, 2006 | 08:02 PM
camSSaro's Avatar
Perfect.The motors is actually at a machine shop getting put together but first he wants to check that and cant seem to come across the information
Thanks
