TSP magic stick 4 with an A4
Old Aug 18, 2006 | 03:57 PM
bjamick's Avatar
Question TSP magic stick 4 with an A4
Ok guys you all know the texas speed 4 camshaft here are the specs anyway it is a 239/242 and .649/.609 lift with a 112 lsa but i have stock heads and stock intake(but maybe an ls6 soon) will it be too much for my car? for now? and another question the RPM range on the cam is 2300RPM to 6500RPM and im wanting to get a torque converter to match this cam yall think like a 3500 or lower?
Old Aug 18, 2006 | 04:25 PM
KingSS's Avatar
4000 and above is probably reccommended on the stall converter, and the cam fits under stock heads without any PTV clearance issues. You might want to look into a LS6 intake though, the car would make a good amount more power with one of those instead of the LS1 intake.
Old Aug 18, 2006 | 04:30 PM
TXZ28LS1's Avatar
i dunno man, that ms4 is a damn big cam!! i go with something like the torquer v.2. if your car isnt a daily driver and is all out for the track, then go for it. but i would probably run a 4k stall for sure.
Old Aug 18, 2006 | 04:31 PM
bjamick's Avatar
ya thats what i figured, well im also going to be running the bottle ive heard with a high stall it seems to lose the effect of the bottle? is this true? oh this is not my DD so i dont care how it idles.
Old Aug 18, 2006 | 04:32 PM
KingSS's Avatar
Ok if you are gonna spray you might wanna look at 3500 or 3800 stall. Those run much better on the spray then the larger converters do.
Old Aug 18, 2006 | 04:36 PM
bjamick's Avatar
ok that is what i was thinking but yall guys prob know more than me im only 18 but im learning very quickly. but i did find a yank 3800 for $450 used with 3500 miles on it so maybe i need to ook into that. i will most likely buy the package from TSP with the cam valve S. and pushrods for the $799 beginning of september. and are cams difficult to install??
Old Aug 18, 2006 | 05:33 PM
KingSS's Avatar
Hey man, im only 20 so im not much older then you, dont worry about it youll learn quickly. They arent too hard, installation is pretty straight forward. Although if its your first one itll take awhile, just from inexperience. I think the most annoying thing about it is installing the Valve springs, that takes about 2 hours in itself. Go to ls1howto.com, there should be a pretty in depth guide to installing a cam on there.
Old Aug 18, 2006 | 06:01 PM
bjamick's Avatar
o ok man good to see us younger guys have actually got good taste, well im thinking not this week but next ill buy it maybe but i just spent 400 2day on HPtuners for it that someone has to teach me how to use it so i can tune it for the cam and headers and all that stuff.
 Michael S. Palmer
Old Aug 24, 2006 | 09:10 PM
stangkiller2005's Avatar
im only 19
well i was plannin on gettin the ms4 aswell and my car is a DD... ive heard that this cam aint that bad for DD either... ive heard great things bout this cam.. and im really anctious to get it installed!
good luck man! and keep us posted on how everything goes!
