LS2 cam in an LS1
Old Aug 21, 2006 | 06:03 PM
89ws6formula50's Avatar
Default LS2 cam in an LS1
anything need to be changed besides the springs to do this swap?
Old Aug 21, 2006 | 08:06 PM
Black Z28 M6's Avatar
why the hell do want to do that for
step up and get a real cam
Old Aug 21, 2006 | 09:13 PM
rocketman442's Avatar
Isn't the cam journals a different size or something?
Old Aug 21, 2006 | 09:25 PM
Billy177's Avatar
X2.....
Old Aug 22, 2006 | 05:31 AM
cause I have a car (GN) that gets all my "real" money and dont intend to spend $400 on a cam and another $400 for a tune and the pushrods and springs etc etc when I can put a stock ZO6 cam in and get a lil more power out of it
Old Aug 22, 2006 | 08:31 AM
redtail2426's Avatar
run at the track before and after..Your times probably wont change but you might pick up a mph or 2.Its helps your top end a little.
Old Aug 22, 2006 | 09:58 AM
1ImperialSS's Avatar
formerly silverbrick (changed 02/17/2013)
im pretty sure the GenIII and GenIV you can interchange cams without a problems. somethings in the heads are a little different but cam, springs and pushrods will swap. (i think)
Old Aug 22, 2006 | 11:59 AM
prostock_bigblock's Avatar
what I know is that the ls2`s has the 01 ZO6 cam so yes they are intechangable. For gains, u went feel the difference.
Old Aug 22, 2006 | 12:30 PM
yeah if its the 01 z06 cam the its not worth it,get the 02 and up z06 cam,which is only worth it if you get a killer deal on it and dont mind tearing down the car for little gains..
Old Aug 22, 2006 | 05:36 PM
yeah, the 02 would be the way to go. I dont mind tearing it down, I have been in to it a few times already
Old Aug 22, 2006 | 05:50 PM
sdbrown84's Avatar
Some say there is a difference above 4K with the LS6 cam. You may want to consider a Stealth or similar grind. Something mild, the engine PCM should be able to tune out, so you wont "need" a tune. Personally I would never do a cam swap without a tune, but to each their own.
Old Aug 22, 2006 | 06:02 PM
silverlt1ss's Avatar
get the tr cheater cam!
Old Aug 22, 2006 | 06:21 PM
JustAnIlluzion's Avatar
sorry to hear about your dad, RIP
Old Aug 22, 2006 | 08:39 PM
HEMIETR's Avatar
LS2 cam doesn't have the reluctor ring on it for the cam position sensor. LS2's cam sensors are run off the cam gear.
Old Aug 22, 2006 | 09:08 PM
mr2guru's Avatar
Exactly....
You can't run an LS2 cam in an LS1/6. There is no cam timing pickup on the back. That's why they are selling for $50 or less in some cases. They are pretty much useless.
You can run an LS1/6 cam in an LS2 though.
Old Aug 22, 2006 | 09:55 PM
^^^ I knew they wouldn't interchange but I couldn't remember why.
Old Aug 23, 2006 | 03:16 PM
Awesomeperfmachine's Avatar
Default It CAN be done
To say the LS-2 cam won't fit the LS-1 engine isn't exactly true. As someone mentioned the LS-1 style cam "reluctor ring" isn't on the LS-2 cams, but if you wanted to swap to an LS-2 timing chain and LS-2 timing cover & sensor, then you could run the LS-2 cam in the LS-1 block...
Old Aug 23, 2006 | 03:24 PM
FastKat's Avatar
What are the differences in the grind specs for the LS2 vs the LS1?? I am interested in this as well, more from an FI point of view though.
Old Aug 23, 2006 | 03:26 PM
that seems like ALOT of time and expense for extremely insignificant gains
Old Aug 23, 2006 | 03:31 PM
HEMIETR's Avatar
I can think of better ways to **** away money.
