Heads cam question
Old Aug 23, 2006 | 03:49 PM
Lythropus's Avatar
Default Heads and Stealth cam selection
I've been doing alot of searching and can't find any info on using nitrous with a reverse split camshaft.
I was originally planning on a Speed Inc. SI007 cam with a set of Patriot Performance LS6 59CC heads (2.055int/1.57exh). I'm looking for a stock like idle with around 11:1 compression. This will be a daily driver (~15 to 20K miles a year) and I still need to run 93 octane. I would like any input anyone has on this combination or maybe another cam suggestion.
I also found some dyno numbers on an MTI Stealth 2 that showed a 28rwhp increase with full bolt-ons and found another thread with a 43rwhp for a Speed Inc. SI007 cam. After alot of reading it seemed as though the SI007 cam was only slightly noticed in a stock car while the MTI Stealth 2 was not noticed by most. I also considered the thunder racing cheater cam but the dyno numbers didn't impress me and it seemed as though customers noticed a difference in the idle. I don't want a lopey idle. I want a smooth, at most slightly lopier(sp?) than stock idle. I need to be able to carry on a cell phone conversation with the t-tops off and a full exhaust (no cats).
Will the PRC 5.3L Stage 2.5 'R' Ported Heads be a better choice over the PPLS6 heads for my combination?
Thanks in advance for the help and patience.
Old Aug 23, 2006 | 06:57 PM
Lythropus's Avatar
Bump, I know someone knows something on this board.
Old Aug 23, 2006 | 08:12 PM
LS1IMPULSE's Avatar
i guess i will say what i hear all the others say in these cam threads, a 224 with a 114 LSA, i havnt heard anything on the si007
LS1IMPULSE's Avatar
i guess i will say what i hear all the others say in these cam threads, a 224 with a 114 LSA, i havnt researched the si007
Old Aug 24, 2006 | 02:04 PM
Lythropus's Avatar
bump?bump?
Old Aug 25, 2006 | 09:36 PM
Lythropus's Avatar
My next to last post on ls1tech.
Old Aug 25, 2006 | 09:49 PM
SSDoubleK's Avatar
Sorry to hear about that, keep trying.
Old Dec 15, 2006 | 06:56 PM
35thsscamaro02's Avatar
Im with Lythro . I wanna know the same thing. I would like about 400 at the wheels and be able to have a some what normal idle. Anybody out there?????
Old Dec 16, 2006 | 09:22 AM
eamador11's Avatar
