Mustang 2 valve 4.6 Gurus inside
Stay away from Sean Hyland as he has ripped so many people off with his stuff and failed motors. VT Engines, Modular Powerhouse are great to work with and have the best reputation.
VT stage II's are pretty good street manners and can bump up some hp as well. Comp 270's tend to have some PTV issues and their 268's are decent. I would give Scott or Jim@ VT Engines a call or visit www.vtengines.com or give Tim Barth a vist at www.modularpowerhouse.com
However, those 3.73's will most likely need to come out so that 2v can make use of those cams. The NPI engines can do really well with PI intake and PI cams and port the stock NPI heads. It is the NPI heads that choke them up.
Stay away from strokers. Our 281's have a long stroke as it is(same as a 351 ci). These motors need bore and Big Bore kits work the best with cams and staying NA.
I agree 100%! The guys over at MPH are GREAT to to deal with and really know those cars inside and out. Buddy of mine is going through them with some VT cams/headwork at the moment.
Jon
Personally, I would not bother with cams on any ford motor, just add boost and your good to go.
Now once your at around 600+ rwhp, then you can consider going to cams, but if your expecting the bang/buck like a LSx motor, you will be VERY dissapointed. 20 hp, to get a car that idles like crap, and a $1200 lighter wallet is not my idea of efficient.
Ryan
Ryan
The problem with mod motors is too little cubic inches and too much stroke. The only way to make power n/a is to rev the **** out of it. Then the intake becomes a restriction. Boost is the only way to go. Yank out the motor and put in some forged low compression slugs and boost it. 450rwhp is realistic and reliable.
Right now VT enbgines has a NA 2V making 365 rwhp and might be swapping for their cams and that should bump it to 380-390.
Some mod motors if built right can make power, Like Al papito's 5.4 DOHC that makes 568 rwhp on motor and runs 9.8's. Just have to built em right and spend a ton of $$ where for less $$ a blower can net you some decent streetable power.
http://foxlakeracing.com/index.php?s...y=Front%20Page
Called P-51. Kenb even has a prototype version from foxlake thats better then the P-51. There is 2 or 3 other intakes. I just prefer this one. As far as limits of cubic inches. DOHC 4.6 are capable of more hp then OHC 5.7 liters.
Whatever, Im not a fan of mod motors. Comparing a 4.6 to a 5.7 is pointless. Its so cheap and easy to build up a 402. Its not like the external dimensions are different.
Its blah blah blah. You can make any engine do whatever you want if you got the money. I only care about hp per dollar.
Bottomline is ford fucked up. They created an engine thats the proverbial jack of all trades, master of none. Its has the dohc valvetrain that can rev to the moon, only to be limited by a and long stroke. Plus the small bore limits any airflow potential of a 4v head. Its a crappy motor.
Originally Posted by zigroid
you're gonna have to explain that one. are you talking OHC 5.7 do you mean OHV?
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
and now GM is making a 505 hp pushrod v8 that owns supercharged fords. how can you say that the mod motor is better? if you cam the the LS7 and put headers on it you have almost 550 rwhp. lets look at flow # for your 32 valve vs. our 16 valve. it cost way more $ to get power out of it and wont make a much power. you wont see a 400 rwhp mod motor that is NA it wont happen
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#33
Originally Posted by SUTTERERMAN85
and now GM is making a 505 hp pushrod v8 that owns supercharged fords. how can you say that the mod motor is better? if you cam the the LS7 and put headers on it you have almost 550 rwhp. lets look at flow # for your 32 valve vs. our 16 valve. it cost way more $ to get power out of it and wont make a much power. you wont see a 400 rwhp mod motor that is NA it wont happen ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
And this is just of guys that go to this site.
http://www.corral.net/forums/showthread.php?t=515518
Boss 330 (556 SAE) 5.4L, Ported 05 GT's (4valve) by
This guys first on this list with a 5.4 liter DOHC, putting down 556 rwhp with 1.6 liters less then a LS7, cammed etc.
Nazman (from Mighty Mustangs) (410/333 SAE) Owner Ported FR500 Heads/FR500 Cams/FR500 Intake. 4.6L HP Champion.
Here's a 4.6, with 410 rwhp 4v. And you this is an old list, and people have gotten more out of these mod motors. And the OHV LS series is cheaper to work on. But in time when R&D falls off, mod motors will be just as cheap. And remember all mod motors have only Ford blocks, and heads. Worked maybe but only Ford produces heads, and blocks for Mustang modulars. So restrictive or how much hp is proven from just the GM block and heads on a 5.7 liter?
oh ya if the ZR1 was so badass why are they not using it anymore?? and it is a bitch to work on
#34
Actually Naz was at 468rwhp this year.
I view the mod motors and LSx motors as pretty much equal. Both are incredible...plain and simple. So well engineered, and they put all their predecessors to shame pretty much. That is absolutely right with the mods motors...they're damn near squared (3.552x3.543) when stock. OHC setups open up top end, so a bigger bore will help open it up quite a bit. I'm still building my LS1, but if/when I get more money, I'd love to build a mod motor. I love the sound of cammin' 4V's. They're are just wicked. Just get a 4.6 iron block, bore it out to a 5.0, some ported 03/04 4V heads, VT or Crower cams, and...honestly, I haven't decided on the intake yet. The FR500 is wicked, because its all variable, but it's $$$. I still think I'd bore it out, keep it around 9.25:1 C/R, get NICE heads/intake - maybe sheetmetal, and add a big centrifugal blower...I'm thinking Paxton Novi 2000 or ProCharger F1. Throw that in something light with a live axle, like a GT, keep it nice and sleepy and that would be a hell of a streetcar.
#35
#36
i dont want to fight here either, but i just think that it is hard to say that the mod motor is better, its all in the eye of the beholder i suppose. and the 7.0 that is 505hhp is stock too. you are comparing moded 4.6 and 5.0 to a bone stock 7.0, i agree that it has 2 more liters, but how much power can you get out of one of these? 600 rwhp+? it is possible with some cnc'd heads and a BIG cam, ect. FWIW how many 400+rwhp mustangs do you see as opposed to LS based. i do agree with you that a OHC motor will live longer with sustained high rpm but look at how GM's "old school" pushrod motor is holding up compared to all of this new high tech stuff. all in all, i dont think fords motors are bad but more power is eaiser attained from a LS motor than a mod with less $ involved. that was more less the point i was trying to get across. i am just stating my opinion and have no use for a pissing contest. good luck with you ford stuff.
again i am not trying to offend anyone here just saying what i think.
nick
nick
#37
Im just pissed that ford made a dohc v8 with a small bore and long stroke. If they would have based it off the old 289, they could have had a beast with 10k redline. Putting dohc hardware on a truck engine makes no sense to me.
#39
nick
nick
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
FWIW I dont think the Mod motor is better. I just know there are many out there running 6's and 7's with them and there are some making 400+ rwhp NA,which is very expensive for a 4.6 as it is a small motor. The 5.4 on the other hand can make 400+ rwhp with a relative mild setup.
#40
Originally Posted by 8banger
Well, it was engineered as a modular system, so that they could use most of the same components throughout the entire line of vehicles. Perhaps that's why.
