Best cam for my z06...
big cams (that perform equal to their size) will not be low maintenance.
Putting duals on LS6 valved heads is retarded in my opinion.
You want more horsepower, then do it right with the already high quality parts available in the Z06.
As for putting duals for the sake of "piece of mind" only means that you are unwilling to maintain the car after modding and you are being a lazy ***.
The 918's are better springs than 90% of duals with regard to harmonic control and power output on any cam in the .600 lift range.
When was the last 918 failure that you've seen here if all was installed properly.
My moto is "do it right or don't do it at all"
That means, degree the cam, match the components carefully, tune it properly, and maintain it regularly.
I just can't see the need to go backward on such a well designed machine such as a Z06.
Think about it this way, if LS6 valves were not so beneficial, why are stock LS6 heads worth 1200$ stock and LS2 heads only 475$ ???
They are the same except for the valves.
My point is you already have good parts, why ignore them instead of benefiting from them?
Haha you make good points but for us lazy guys the duals do the job well...plus not many people know how to shim springs correctly nor can they do them themselves. I am not experienced enough to shim them myself and plain do not have the time to be digging around in the valvetrain checking on my springs to see if they need to be replaced, therefore I went with the PRC duals since the lift on my custom ground cam is .630 intake and .6XX exhaust. If your up on maintainence then by all means go with the shimmed 918's as Predator knows tons about valvetrain combos and im sure they will work great with the LS6 valves. BTW Predator do the ls6 valves need to be switched out if duals are used or do they just not work as well as the lighter 918s?
Quick question about springs - I have the Comp 921 with my Z that was done by Lou G of LG Motorsports. It was in his cam kit. As I am not as familiar with the 918's, are the 921's not good? I have 475/422 on 13:1 AFR. It pulls a lot more if I lean it out (My AFR heads can take more).
Thanks,
JG853
I was told by TSP to use a dual PRC springs on my Torquer V2, which I did and I rountinely spin the motor to 7200 rpms. I've checked the valve train several times and no trouble, things look good and I'm making over 480 rwhp in my ZO6.
And yes these LS6 heads are excellent as is, but going to a large cam over .600 lift with agressive lobes might require different springs. (I said might).
Along the same line my sons GTO broke a spring (ETP) and if it werent for the duals things would have been nasty. We changed them all to 921's and the valve train is actually quieter.
I took a tour of Katech recently, thanks to Jason and he was telling me of the success they have had with the beehive springs. The main reason for this is that they are lighter and the motor (LS7) doesnt need to spin that high to make power so they can get away with a lighter spring. And they have better harmonics than some of the others.
I truly believe that anyone putting together a quality motor need to research all the options. I myself believe that if you are going to do it, do it right the first time. I researched and asked questions for months before settling on my current combo and if I had to do it over again I wouldnt change a thing. How many people can say that? Probably only a few.
I'm lucky as I'm in the middle of some the best race shops and engine builders in the country and I was able to draw on some of thier experiences.
Remember its the sum of the whole that will make your results worthwhile.
Thanks,
JG853
springs.
I have to believe that a respected corvette vendor, LG Motorsports, packages these cam kits with Dual springs for a reason
I don't claim to be an expert on this subject so someone please correct me if I am missing something here...
The 918's would be perfect for that cam and those valves.
