Fuel Injectors.
Old Aug 27, 2006 | 10:36 PM
LFNDUST's Avatar
Default Fuel Injectors.
Okay I've been trying to search, but for some reason I can't get the search to work at all. So no one say you can search and find this.
I'm doing a cam install (Specs below) I was wondering if I should replace the stock fuel injectors with new ones? would it not be a bad idea? Should I go with some ls2 injectors? would they work? or are they the same as the ls1 injectors?
Heres my setup!
Cam :
231/237 .598/.598 111+1
Springs:
918 Springs
Oil Pump:
LS6 Oil Pump
Timing Chain:
LS2 Timing Chain
Push Rods:
chromoly 7.400 (stock length)
Thanks for the info in advance.
Old Aug 27, 2006 | 10:39 PM
RoastEmSS's Avatar
it will def be smart to swap injectors...go with some SVO 30# injectors from speedinc, or ebay or whatevers cheapest
Old Aug 27, 2006 | 11:10 PM
LFNDUST's Avatar
stock fuel pump alright to use?
Old Aug 27, 2006 | 11:32 PM
RoastEmSS's Avatar
yup..
Old Aug 27, 2006 | 11:50 PM
LFNDUST's Avatar
thanks for the info...
