T Rak questions
Old Aug 28, 2006 | 03:00 PM
1slow98Z28's Avatar
Default T Rak questions
Well i just got off the phone with Thunder Racing and the said the Trak cam would be good for my car on the street.... if i do this cam and the 90/90 set up n port and polish my heads and have a vig 3600 stall would i make it into the 11.5-11.8 range??? also what all do i need to change besides springs and pushrods?? i was wanting the Trex but he said be to crazy in an auto car for the street need atleast a 4400 stall..
Old Aug 28, 2006 | 03:08 PM
LS1IMPULSE's Avatar
This cam seems to getting popular lately? I was looking into it for the last 3 weeks but decided that I will most likely not go with it, becuase I am unsure of the p2v clearance, and what something that wont require me to check/replace springs every couple thousand miles. turbosix just got his H/C setup finished with the T-rak and should be posting dyno results today, and antoher person posted last week they finished a swwap for the T-rak and really liked it even when it wasn't tuned yet.
Old Aug 28, 2006 | 03:13 PM
JZ'sTA's Avatar
Fluck yeah you would.
You would make it there easy as long as you have a good tune and good 60 ft time.
Old Aug 28, 2006 | 03:55 PM
1slow98Z28's Avatar
would the SLP ls6 intake be good with it or should i do the 90/90..... also would i need to change my oil pump?? or what eles should i change?
Old Aug 28, 2006 | 04:00 PM
1slow98Z28's Avatar
oh yeah he said you wouldn't be going though alot of spring he said to change them maybe 15000-20000 miles
Old Aug 28, 2006 | 04:27 PM
Josh@KY-Turbo's Avatar
The Trak also work with stock unmilled heads. P/V clearance become a concern with milled and aftermarket heads. I am tossing around the idea of using this cam or just going with the MS4 and TSP/PRC CNC LS6 heads. My rear end would have to wait to be ordered if I do heads and cam. Decisions, decisions...
Old Aug 28, 2006 | 04:53 PM
1slow98Z28's Avatar
soo would it be better to port them or just leave the stock ones?
Old Aug 28, 2006 | 04:55 PM
Portting them would definatley help out. I just would not mill them trying to raise compression without being leary of P/V clearance issues.
Old Aug 28, 2006 | 05:56 PM
LS1IMPULSE's Avatar
PP would help, just make sure to keep you OEM valves aswell, and if you are serious are doing the heads aswell the 243 casting heads are on sale untill labor day for 995 assembled to there stage one specs with patriot springs which you will need anyways for that cam so you may want to consider that, as for the springs you will most likey not have to replace them for every 15-20K miles but it would be a good ides to atleast check them every 5k or so
Old Aug 28, 2006 | 06:01 PM
HOSS's Avatar
depending on the price of the port job, I would look are getting a set of cheap ls6 heads instead. I would get a LS6 oil pump and LS2 timing chain. Most of the larger cams from anywere are going to require you to change your springs every 15-20k, if you don't want to do that, don't get a big cam. Its a great cam by the way, about time people start to realize it.
