427 Lunati ls1 kit question
......... I have never heard of a block comming part for any reason other then a Wheelie stand , or a rod/crank breaking and putting it threw the side, and then it wouldnt matter if it was an ls1 (any year) or a ls6,ls2,ls7. nice 454 btw.
jsconiers if you want a 427 get an ls1 block (any year) sent it to Race Engine Developement and have Steve work his magic and make it an MID ... all problems solved. and you have a BADASS block for less than the price of a C5R , Warhawk, the new GM block . With an MID you can do the same boring or at least clost to the Warhawk.... oh and it weighs less too.
My MID i only went 4.125, i am already planning on future rebuilds
LS2 is a nice option and in all honesty if i had that option before i started mine i would have used it.
Ask you self why you want a 427 or bigger, either way you look at it not only is bigger better but it cost more too.
Katech is now selling Value 427's short blocks.
And as far as Lunati , its quality.
JS, alot of the sponsors to the right will build you a 402 for much cheaper than you could ever think about a 427. Hell, some places are doing .030" over bores on the LS2 sleeves and throwing in 4.100" eagle cranks and getting 418 cubes for no more cost than the 402. You just have to weigh your options and you budget.
The 97 98 blocks however do not have the cross over oil galley at the back. I wrote a program to machine the block to join the galleys together for improved oiling as in later blocks. There is minimal charge for this machining.
I can do the same modification on the iron LS blocks.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve
lie to me if you have to.
By the way if anyone doesnt know, STEVE is DA'MAN!.... When he is done with a block you want to wear it around your neck and show it off like a new born.
Steve
MID it and join the Family!!!!!!
Steve Demirjian
Oceanside, Ca.
760-630-0450
Or, an even cheaper route, build a 6.0l LQ9 or even your current LS1 with parts to handle N20 and run the same 300 shot. Drives nicely through town, doesn't kill the wallet and could put down high 9s low 10s with the flip of a switch. Whatever you do, you better expect to get a new rear, tranny and suspension. All the accessories from your LS1 should swap to the LS2 or LQ9 based shortblocks.
Steve
