View Poll Results: G5X3 vs. MS3
LG G5X3
48.92%
TSP MS3
51.08%
Voters: 139. You may not vote on this poll
G5x3 vs. MS3
Old Sep 13, 2006 | 08:54 PM
  #61
99blancoSS's Avatar
Hi Bob last question from me on the subject here. I know you said it wont clear stock heads on a 110 lsa. What about with -2cc valve reliefs? If it would clear would I benefit on the low end better?
Old Sep 14, 2006 | 08:01 AM
  #62
Louis's Avatar
With reliefs, it would be fine. Plenty of room there. Want it on a 108?
Old Sep 14, 2006 | 08:45 AM
  #63
purdueranger's Avatar
That would be sick. Do you have a car that could be a test model for this.
Old Sep 14, 2006 | 09:36 AM
  #64
99blancoSS's Avatar
Interesting, very interseting idea. How would it benefit me? I thought I read it would be better for torque down low but will take away from hp up top? I've still got 3 weeks before my engine is done but I'm guessing if I'm gonna custom order I should do it soon.
Old Sep 14, 2006 | 12:05 PM
  #65
Louis's Avatar
Email Sent
Old Sep 14, 2006 | 12:49 PM
  #66
PREDATOR-Z's Avatar
This is what I would run:
235/242 .646/.610 112+2 That is an additional good 10+ rwhp on the G5X3 with suporting combo and better under the curve
Old Sep 15, 2006 | 06:33 PM
  #67
VENGEANCE's Avatar
I dunno, but to me i dont trust any cam i dont know the exact specs on....
Old Sep 16, 2006 | 01:26 AM
  #68
PREDATOR-Z's Avatar
G5X3 is a 234/242
Old Sep 16, 2006 | 11:25 AM
  #69
99blancoSS's Avatar
.646 lift is insane pred, I'm thinking about a 108 on x3 though with 4 degrees advance ground in. What do you think its charateristcs will be like? I'm trying to make the long duration more low end friendly.
Old Sep 16, 2006 | 11:34 AM
  #70
PREDATOR-Z's Avatar
That is where the LSK lobe on intake will come into play. What i did is just swap the XE-R intake for a LSK one.
I'm contemplating running that cam in my 370 ci (A4)
108+3 will definately bring the power on much earlier, but it will be peaky and might not benefit from 7000 rpm blasts.
But with 29* overlap that WILL be insane The VE.s look good, more exhaust biased. worth a try IMO
Old Sep 16, 2006 | 03:06 PM
  #71
RDeputy150's Avatar
Louis, could you send me an email/pm on the 108/110 also? What would the benefits be? Thanks!
Old Sep 18, 2006 | 06:36 PM
  #72
waterbug1999's Avatar
Hey Louis.. How do the X3 cams like spray? I have the 114 and now I am going to spray 100 shot.
Just curious as the spray install is almost complete..
Old Sep 19, 2006 | 08:00 PM
  #73
lilbuddy1587's Avatar
6 degrees of split in the cam, you tell me
Old Sep 21, 2006 | 04:22 PM
  #74
99blancoSS's Avatar
What size pushrod? I'm using shaved heads. 64cc shaved to 59cc chambers, not sure of how much they take off?
Old Sep 22, 2006 | 08:09 AM
  #75
allngn_c5's Avatar
I have hardened 7.400 PR's . They came in the valvetrain upgrade kit from LG Motorsports when I bought the G5X3 cam.
Old Sep 22, 2006 | 08:27 AM
  #76
NastySSoo's Avatar
Hey Lou,
What lifter do you recommend with the G5X3? Myself and a few others have had problems with stockers , comp replacement, and comp rs? Your shop told me that "people arent having as much problems with the Rs, but still some failures" Whats your opinion?
Thanks Paul
Old Sep 25, 2006 | 05:18 AM
  #77
PREDATOR-Z's Avatar
There are the "NEW" gm replacement. Cadillac CSTV units
Old Sep 25, 2006 | 09:30 AM
  #78
bad intentions's Avatar
Default 6.0 with G5X3
will a stock 6.0 lq9 work good with G5X3 cam and its stock 317 heads and of course ls1 intake and if so what lsa could i get at. i need some advice on which cam to get cause i want to see low numbers oh and this is going in a 2000 camaro..
Old Oct 3, 2006 | 07:39 AM
  #79
N4cer's Avatar
Funny, when I called LG to order mine on a 110, the guy REFUSED to do it.
Old Oct 3, 2006 | 10:27 AM
  #80
99blancoSS's Avatar
After considering everything I had LME work with someone and spec me out a cam for my car. Looking at my cars weight, gearing, n2o and how I want it to drive it they came up with something in the g5x2 range on a 112 lsa with 6xx lift. Not sure of the lobes. Its the best way to buy a cam but if I had to buy another off the shelf it would have been the x2 or x3.
