View Poll Results: G5X3 vs. MS3
LG G5X3
48.92%
TSP MS3
51.08%
Voters: 139. You may not vote on this poll
G5x3 vs. MS3
Old Oct 14, 2007 | 06:59 AM
  #101
AU N EGL's Avatar
Originally Posted by PREDATOR-Z
That is where the LSK lobe on intake will come into play. What i did is just swap the XE-R intake for a LSK one.
I'm contemplating running that cam in my 370 ci (A4)
108+3 will definately bring the power on much earlier, but it will be peaky and might not benefit from 7000 rpm blasts.
But with 29* overlap that WILL be insane The VE.s look good, more exhaust biased. worth a try IMO
That works for me.
Or what about an X3 110 on SWGT heads ?
Old Oct 16, 2007 | 11:49 PM
  #102
02blackbeauty19's Avatar
So has anyone actually tried running the 59cc AFR's with .040 cosmetic and the G5x3 cam without flycutting ???
Old Feb 28, 2009 | 07:39 AM
  #103
allngn_c5's Avatar
Originally Posted by Louis
Doug- We flycut the majority of our installs for a few reasons even though it isnt necessary. They will clear fine, but you have to remember, the volume of work we do, we have to idiot-proof the installs so the customer can bang the 3-2 miss-shift and not tap any valves at 8500 . If we didnt, that one customer would bend a valve or 8. Most people never have that issue, and the DIY Guy doing stuff at home knows what he is working on.
I will never turn anyone away from flycutting, and lets keep in mind that most of the time its necessary, just not with the combos everyone is asking about
Wavrdr- this is a very common combo as you probably know. Rule of thumb is .055-.060 min. on the intake (thats close), and 80-100 on the exhaust. The more the merrier. With that setup (X3/114, 59cc AFRs and cometics) You are looking at ~ 80I/130E. Everyones setup will vary, but thats been the number.
Louis
OLD post, but believe it or not this is the first time I got an answer to my stock head and flycut with the g5x3. LOL, I guess better late then never, thanks Louis.
Old Feb 28, 2009 | 05:30 PM
  #104
slowandrichws6's Avatar
Originally Posted by Patrick G
G5X-3 all the way. It makes much better dynamic compression than the MS3 (because of the narrower LSA and advanced ICL). This will give you much more power under the curve. The MS3 is very much a top-end only cam in comparison.
the man has spoken....i would listen if i were you
