cam, and springs?
Old Sep 3, 2006 | 02:26 PM
white99z28's Avatar
Default cam, and springs?
I recently purchased a comp cams cam, and springs. The cam is a 222/224 .566/.568 It came with 915 springs. Do I need 918's? Also, if you have any advise on which tool to use on the lifters, that would help too.
Thanks
Evan
Old Sep 4, 2006 | 02:43 AM
FIVE-O's Avatar
New/Used? Good little cam...you'll enjoy it. 918's would be my choice.
Old Sep 4, 2006 | 03:51 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You should be fine with those springs as long as you don't plan on sending it to 7k rpms.
Wooden dowel 5/16" about 2 feet long works nicely to hold the lifters up. Or brake line.
Old Sep 4, 2006 | 07:40 AM
vettenuts's Avatar
I know someone running Z06 springs with that cam, so you should be fine.
Old Sep 4, 2006 | 10:37 PM
white99z28's Avatar
ya, I saw the jpr tool, I wanted to know how to make it, if that's all it is, then I will be going to home depot in the morning. I am tired of this cam just sitting here.
