Cam gurus: Please pick for best street cam for 01 Z06:
LS1 Tech Administrator
Originally Posted by Slowhawk
I agree with Patrick. Forget the duration for idle quality It's about valve event's and testing.
We've been running 110-112 advertised duration Cams forever in A4's when everybody said they won't idle right.You can have a 110 duration Cam idle just as smooth as a 114 duration Cam
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Originally Posted by KB99WS6
But will a 228/232 on a 114 idle better than the same on the 110+1? I wish I could hear a sound clip or hear from someone who has this cam or similar...
Patrick, can you give me a comparison of how the TSP 228R on a 114 or even 112 will compare to predator's recommended 228/232 110+1 cam both in power and idle.
Thanks!
Thanks!
I recently installed the 228/232 588/595 on a 110+1 LSA. It is on my 01 C5 6spd. I'm no cam guru but really like this cam. (Patrick recommended this cam to me.) It has good power under the curve and a nice little lope to it. Although it will buck in 1st gear when rpm's are around 1200 or so, this really hasn't been a problem to me. The right tuner might be able to take care of this. One thing I can tell you from my experience is get the cam degreed, don't go just by dot to dot. I learned this the hard way and it cost me extra money. Here is a soundclip of the cam with the mods listed in my sig.
http://media.putfile.com/228232-110LSA-on-Startup
Originally Posted by PREDATOR-Z
Yes the Z06 has a M12 tranny with shorter gear ratios, it will be fine.
If yoou decide on this cam, just make sure it is degreed to assure 110+1 install.
I won't be the one installing it, a shop will. Should they automatically know to do this, or is this somethign extra I have to tell them. What happens if its not "degreed"...whatever that means
Thanks for the clip pewterme, sounds pretty good. Kinda iffy about the fact that you have bucking in first below 1200rpms though, b/c that would be a nightmare in traffic that I sit in sometimes. I am having the Vette Doctors dyno tune the car when done, but I hope this isnt a normal thing for that cam.
Predator - Is it normal to experience bucking under 1200 rpms in first with that cam, or is that a tuning issue? Also, what lifts should I get if I use XER lobes? the same as pewter has? I need the full specs please
Cantdrv - a 114+4 eh? What does the +4 do compared to the regular 114? Does that move the powerband down while still keepinmg nice idle of the 114?
Few more questions on this cam.
Where will the power peak? I don't want to raise the stock rev limiter, or maybe only a little bit. So need a cam to make best use below that.
How will low-end and midrange tq be compared to stock? I enjoy when I am on the highway and can just barely blip the throttle in 5th gear and the car just flies forward effortlessly.
Again, will this cam be fine in heavy stop and go traffic and a huge pain in the ***? (assume a good tune).
Ok, I have my LT's now and I am about to buy a cam and have narrowed it down between this custom cam and the TSP 228r. Please help me decide. What would the specific difference be between the two. Thanks!
i love my TSP 228R, i wanted a cam that would keep a decent amount of tq down low, (my car is very heavy compared to a vette), and that would make a decent amount of power up top, i didn't want to replace my stock clutch, or gear up to make for the loss of power down low, i drive 130 miles to get to office (round trip), lots of topics helped me to choose this cam, i know there are better options for better TQ, or for more HP up top, i wanted to have kind of like half and half, and so far and very happy with it.
dyno before cam
dyno after cam
hope this help.
dyno before cam
dyno after cam
hope this help.
The 228/228 XER cam is an excellent choice for a DD. I have the same cam on a 114 +4 LSA....It makes over 450rwhp and 410rwtq with my PRC stage 1 heads....Excellent power across the board. 300 rwtq at 2500 rpms....
a couple of nice argument for the TSP228r! Theres a guy on the corvette forum though that only got 416rwhp in an 02 Z06 with AFR 205's + TSP 228r (with supporting mods, LT's etc). the dyno was in 103 degrees and running 91 octane but thats still really low! Cantdrv65, now thats more like it!
Now, I am not sure which LSA to go with, 112 or 114?? If I choose 112, or 114 on their drop down menu does it automatically have the +4 advance in it?
There are plenty of cams that will make more power but not enough to sacrafice fuel economy etc. Regardless I still consider this cam large (funny eh?) and it requires a tune.
