poll: meanest sounding cam
Int 321 + Exh 336 = 657 / 4 = 164.25 - 112 LSA = 52.25 * 2 = 104.5?
BTW the cam is a Comp Cams Super Comp
Drag Race 321JR-12 Mechanical Roller Camshaft Only
Lift: .748''/.748''
Duration: 321°/336°
RPM Range: 5000-7500
I think those are the .006 numbers, you need the .050 numbers.
That right there is the meanest sounding cam I've ever heard on an LSx....
I AGREE 100% .............
How hard does that thing chop? What idle speed do you have it set at? I will be using a 257/266 on a 110 lsa and I am getting anxious. I was told it is going to chop real hard. I was thinking of an idle around 650-700 if it will stay running at that low of an idle. Thanks for the input.
thats that I was thinking. I def. dont want to be the one to brake those straps on the dyno.
yes, more overlap, more chop.
still trying to figure out the name of that band myself. like it.
Not sure what I want now!
