ls1howto....
Old Sep 9, 2006 | 08:54 AM
aw01m6t\a's Avatar
Default ls1howto....
is anyone else having a problem accessing this site. i was wandering how to get the lifter valley cover off\ remove the connectors holding it in?
Old Sep 9, 2006 | 09:40 AM
ArcticZ28's Avatar
lifter valley cover? Do you mean the lifter trays or the valley cover? There are only connectors (knock sensors) in the valley cover. All you have to do is get some long needle nose pliers or something of the sort and squeeze the plastic top so that they release. Then just unthread the knock sensors. As for the lifter trays, just unbolt them.
Old Sep 9, 2006 | 10:56 AM
aw01m6t\a's Avatar
my bad, not familar with Ls motors, just older junk. started head\cam swap and w\o being able to get to ls1howto i assumed, and assumed wrong. after prying it up a little i noticed nothing was there. time to buy a service manual......at least for install. i'm assuming the lifters are under the heads?
Old Sep 9, 2006 | 11:03 AM
Fratsit's Avatar
Yeah.... I have not been able to access the site, too.
I am in the last stages of my cam install and was looking to go over the write up again. Luckily I have read the Cam/Valve Spring Install write-up a thousand times.
Only need to re-install the front cover and balancer then I can get the headers started.
R/
Frat
Old Sep 9, 2006 | 11:14 AM
ArcticZ28's Avatar
Lifters are under the heads. Not sure where in MD you are but if you need some help I'm around the area.
Old Sep 9, 2006 | 11:17 AM
aw01m6t\a's Avatar
i hope it's up soon, after this little incident, i'm reluctant to continue yanking things blindly.
Old Sep 9, 2006 | 11:20 AM
aw01m6t\a's Avatar
Lifters are under the heads. Not sure where in MD you are but if you need some help I'm around the area[/QUOTE]
i'm near indian head, hidden in the woods of so.md
Old Sep 9, 2006 | 11:25 AM
Bill Bowling's Avatar
I have most of the ls2howto write ups here:
http://www.bowlingss.com/LS1_How_To.htm
Bill
Old Sep 9, 2006 | 11:32 AM
Fratsit's Avatar
Bill
Hey!! Thanks Bill.
R/
Frat
Old Sep 9, 2006 | 11:36 AM
Fratsit's Avatar
Its back up. Got it open in another window now.
R/
Frat
Old Sep 9, 2006 | 11:46 AM
aw01m6t\a's Avatar
[QUOTE=Bill Bowling]I have most of the ls2howto write ups here:
thanks man, that's a big help
Old Sep 9, 2006 | 12:23 PM
67Firebird455's Avatar
Yeah it is... That's a big deal. Awesome, thanks a bunch! =)
Old Sep 9, 2006 | 01:37 PM
slt200mph's Avatar
I beleive that the knock sensors in the valley cover call for 22MM socket to remove.. if my memory serves me ..
