What is the difference in these cams
Old Sep 13, 2006 | 07:15 AM
wilddawg's Avatar
Default What is the difference in these cams
I ordered a cam from TSP set up as follows 220/222 @050 581/581 lift 114 lobe sep. centerline 110 +4
They sent me 220/222 @050 581/581 lift 110 lobe sep. 106 centerline
What will be the idle and performance difference. need help quick before I send the cam back.
Old Sep 13, 2006 | 07:20 AM
bjamick's Avatar
i doubt it the only dif is the lsa and that cam they sent you will cut up more and the power curve for that cam will come alot sooner with the 110 lsa.
Old Sep 13, 2006 | 07:36 AM
LS1IMPULSE's Avatar
yup that cam will have a lopey idle with the 110 but like bjamick said, you powerband will start lower in RPM's
Old Sep 13, 2006 | 07:47 AM
PREDATOR-Z's Avatar
It actualy is a good torquer cam, 1* overlap
These are the VE's
0.050
220
222
110> LSA
106>ICL
4>IVO
36>IVC
45>EVO
-3>EVC
114>ECL
1>overlap
It will peak very early like 5700/5800 and with 45 EVO make a Sh*tload of trq at mid/low range. It will be very peaky with shiftpoints around 6100
Old Sep 13, 2006 | 08:22 AM
wilddawg's Avatar
predator Z you are good man I beleive you peaked the cam card. How bad will the lope be on this cam I wanted to kinda stay on the stealth side of things and good idle quality for a DD
Old Sep 13, 2006 | 02:24 PM
PREDATOR-Z's Avatar
Not bad at all, just 1* overlap, a nice little chopchop
