Identify LS6 engine
Old Sep 13, 2006 | 04:40 PM
Obelix G.'s Avatar
Default Identify LS6 engine
I have a long block which is supposed to be an LS6, though I would like to know for sure if I do have an LS6. The exhaust manifolds do look like the z06 manifolds versus the regular c5 manifolds. The funny thing is, this engine came out of a convertible. :\ I am hoping someone swapped an Ls6 in...
How can I verify the internals are of an Ls6. I understand about the block and heads, however, the heads could be put on an ls1, and some ls1 engines shared the ls6 block.
Thanks
Old Sep 13, 2006 | 05:02 PM
LSGunZ28's Avatar
block casting number. name it!
Old Sep 13, 2006 | 07:44 PM
RiceKilla's Avatar
Look on the rear of the block right under the driver's side head, there will be a casting number.
If you have ls6 heads they will have a 243 casting number on the corber of the head. If you have 241, theyre just ls1 heads.
Old Sep 13, 2006 | 10:34 PM
Obelix G.'s Avatar
Are we talking about the 12561168 casting number? I don't see how that would help me since some "Ls1" cars used surplus "Ls6" blocks. I am just trying to rule out someone putting Ls6 exhaust and heads on an LS1 block.
Old Sep 14, 2006 | 07:51 AM
Justin00SS's Avatar
What would really be the advantage of it being an LS6 block though?
LS1/LS6 is 5.7L 346 c.i.
Same thing.
Old Sep 14, 2006 | 03:47 PM
Camaro Rick's Avatar
There are several internal advantages...
Example: The LS1 pistons are made of a metal listed as "M124" - the LS6 pistons being "M142" which has a higher nickel and copper content. The LS6/m142 pistons are stronger and expand less under high temperatures, thus allowing them to reduce the bore clearance. Reducing oil consumption and increasing overall and high rpm durability. This information was taken from "How to build High-Performance LS1/LS6 V-8's" by Will Handzel. Incredible referense book for anyone who wants to know more about our motors...
It also lists the LS1/6 block number being #12561168 from 99-02. Not sure if there is an LS6 specific casting #. Apparently 01-02 LS1 blocks were almost Identical to LS6's. Hope this helps atleast a little.
Rick M.
Old Sep 14, 2006 | 03:52 PM
Justin00SS's Avatar
Rick M.
Yeah but if the LS6 block came out of an f-body then it would have the LS1 pistons right?
Old Sep 14, 2006 | 04:03 PM
The Hopkinator's Avatar
. Id say because Ls6 is a Z06 engine. I have a ls6 on order , and thats why I chose it. Putting in the LT cam and a spring mod,,Figure if Chevy thought enough of the LS6 to put it in a Z06 Corvette , it was a good motor. Then again, I may be a moron.
Old Sep 14, 2006 | 04:05 PM
ISeeRed's Avatar
The bottom of the cylinders have vents cut in them on the LS6
Try this: http://www.cadillacfaq.com/faq/answe...0of%20power%22
this article may help
Ray
Justin00SS's Avatar
Nobody is saying that it isn't.
Old Sep 14, 2006 | 04:06 PM
Justin00SS's Avatar
Ray
Sweet thanks. Knowledge is power.
Old Sep 14, 2006 | 04:07 PM
ISeeRed's Avatar
See the article above
Old Sep 14, 2006 | 07:58 PM
Obelix G.'s Avatar
I guess what I need is a casting number on the crank or pistons to be different than that of an LS1. Any ideas?
Thanks for the help thus far!
Old Sep 16, 2006 | 06:54 PM
Obelix G.'s Avatar
Anybody?
Old Sep 17, 2006 | 04:06 PM
ISeeRed's Avatar
If it's casting numbers you want go here: http://www.automotiverebuilder.com/ar/eb040538.htm
There are some differences in the LS6 Crank.....
Ray
Old Sep 19, 2006 | 10:51 AM
Obelix G.'s Avatar
That link lists the LS6 crank as the same casting number as the LS1. What do you know about it?
Old Sep 19, 2006 | 03:22 PM
Justin00SS's Avatar
I thought the LS6 had a stronger one but it was the same in dimensions.
Old Sep 19, 2006 | 08:23 PM
Cop Car's Avatar
does it have 243 heads? thats the LS6 head. 241 and 853 are the LS1 casting numbers.
run the block number. thats the only real way you will find out
there is no real advantage between a LS6 block and LS1 block, LS1 blocks are actualy stronger
Old Sep 21, 2006 | 07:52 AM
VA2001SS's Avatar
So GM made a weaker block for a higher HP (LS6)application
Old Sep 21, 2006 | 12:10 PM
Cop Car's Avatar
the short answer is... yes they did..
we are talking about lots of hp here..
