Head Studs
Old Sep 14, 2006 | 02:24 PM
Raven02TA's Avatar
Default Head Studs
Does anyone have the tq specs for ARP head Studs? or are they the same as the GM specs? i figure the sequence is the same but i dont know the specs
Old Sep 14, 2006 | 02:25 PM
jermstyle's Avatar
http://www.blackcamaro.com/headstud.htm
Old Sep 14, 2006 | 02:47 PM
Raven02TA's Avatar
thanks brother much appreciated!
Old Sep 14, 2006 | 02:58 PM
jermstyle's Avatar
np.. I just put some in my block, very sweet.
Old Sep 14, 2006 | 03:01 PM
Cop Car's Avatar
yeah, i just got my studs and it says to run them down hand tight (to the bottom as it says on the site) and then to torque the nuts to a set ammount... im not sure what that ammount is though, probably the same as he said on that site
Old Sep 14, 2006 | 03:02 PM
Raven02TA's Avatar
ive had them in my block for a year or so now, i just lost my specs thanks again
Old Sep 14, 2006 | 06:36 PM
silverZ98's Avatar
just did these on my car i whent 30-50-then 75 with arp lube
Old Sep 15, 2006 | 12:50 PM
Raven02TA's Avatar
recieved an email back from ARP this is what im told just for future reference if anyone does a search.
"HELLO CHRIS
ON THE LS1 THE STUDS GO IN THE BLOCK HAND TIGHT ONLY 1 TO 2 FT LBS THEN
WITH THE ARP MOLY LUBE ON THE THREADS AND WASHER TORQUE THE 11MM STUDS
TO 70 FT LBS AND THE 8MM STUDS TO 23 FT LBS WITH MOLY AND the tq
sequence is THE SAME AS FACTORY
THANK YOU
RON F"
