Pulling an LS1 out of an Fbody...
Old Sep 16, 2006 | 03:48 PM
s346k's Avatar
Originally Posted by Cop Car
the car i had was wrecked in the front, i sawzalled off everything in the way, unbolted the k member and trans member, and pulled it all out the front/bottom. put the car on jackstands and lowered the motor onto a small cart and pulled it out from under the car with a dixie chopper. and who says im redneck?
that's horrible, what kind of moron would do all that to an ls1 f-bod? oh that's right, you would..because you know nothing of these cars.
Old Sep 16, 2006 | 03:51 PM
gearheads78's Avatar
Done it both ways and bottom is easier.
-Unplug the harness under the dash and feed through the firewall
-disconect fuel lines
-disconnect A/C lines, radiator hoses, and trans lines if auto
-unbolt struts at shock tower
-unbolt trans cross member and torque arm
-unbolt k member
-lift car and drag out entire assembly
-unbolt motor mounts and disconnect steering hoses set motor/trans aside
-roll k-member/suspension assembly back under car and bolt up
all can be done in about an hour with air tools or a couple hours by hand
good luck
Old Sep 16, 2006 | 04:05 PM
joshp14's Avatar
With everythung unbolted, attach the cherry picker to the body and lift. Simple right?
Old Sep 16, 2006 | 05:41 PM
jfman's Avatar
So does that make me a moron ?
If his looked like this.... I dont blame him
Old Sep 17, 2006 | 02:03 AM
s346k's Avatar
it was a joke...and the front of his car is/was much worse.
Old Sep 17, 2006 | 02:05 AM
Cop Car's Avatar
dont listen to anything s346k says, he is a jerk. he just has ***** envy
we are friends and just give each other a hard time.
Old Sep 17, 2006 | 02:28 AM
SPECIALIZED STAINLESS's Avatar
From the bottom FTW. Here's some pics of my Camaro during the process. I put the entire motor/trans and accesories back together on a cart, rolled it under and just lowered the car down on top of it all and bolted it back up
Old Sep 17, 2006 | 02:31 AM
jfman's Avatar
Jackstands on ramps That looks dangerous man !
thanks for the pics !
Old Sep 17, 2006 | 02:41 AM
Dangerous is my middle name
Old Sep 17, 2006 | 02:43 AM
jfman's Avatar
Yeah I'm gonna just simply hang my donor from the ceiling
Old Sep 17, 2006 | 02:48 AM
Boodyrider's Avatar
I think I will do it from them bottom...
I'l just reinstall the Kmember so I can keep the car a roller...
Bingo. First disconnect the torque arm and shifter (don't forget the clutch line if a manual). Inside the car, disconnect the 5 or so plugs that run from the underhood harness through the hole in firewall under/behind the PCM. Pull therough, lay on top of engine. Disconnect the struts at the A-arms, unbolt the spindle from the upper A-arm, disconnect the brake lines that go to the front wheels only, and don't forget to unplug the ABS sensors inside the wheelwell. Pull the trans, engine and K frame together, then use an engine hoist to reinstall the K frame, reattach the brake lines and struts, as well as the spindle. Oh, steering shaft, too.
It's SO much easier than taking the trans off first and trying to come out the top.
Old Oct 19, 2006 | 06:37 PM
  #32
CamaroSS_2002's Avatar
could this be done out of the bottom without disconnecting the AC?
and could you use a tranny jack to support the k-member or do I really need a small steel kart.
Old Oct 19, 2006 | 07:07 PM
  #33
code4's Avatar
Yes I left our AC connnected. A low tranny jack would work, we made our own cart out of 2X6's & some home depot wheels.
Old Oct 19, 2006 | 07:08 PM
  #34
code4's Avatar
We just let the ac compressor hang down.
Old Oct 19, 2006 | 07:12 PM
  #35
Cerebrex's Avatar
obviously.
Anyway, go out the bottom- it's so much easier.
Old Oct 19, 2006 | 09:45 PM
  #36
hey do you have anymore pictures from your removal? Thanks
Also curious to know if anyone knows if there are any other write-ups on removing from the bottom on the internet.
Old Oct 20, 2006 | 01:17 AM
  #37
code4's Avatar
I don't have any pics that would help you much. There is a book you can get about LS1's by Will Handzel off ebay or where ever for under 20 bucks. It has a step by step removal process that is pretty accurate.
I disconnect & remove the computer then remove the pass side kick panel & disconnect the wires, pull them through the firewall & set it on the engine. The rest is pretty much looking for what needs to be disconnected.
Basically there are 3 bolts on each side of the K member, 4 bolts on each shock tower & the trans crossmember when you are ready to lower the engine/tranny.
Old Oct 20, 2006 | 09:50 AM
  #38
Really? Didn't know that Will Handzel book listed the way of removing the engine from bottom... I've seen that book and thumbed through the pages several times... Thanks.
edit: just picked up the book at AZ and found the answer to the question. The book DOES NOT require you to disconnect your AC when doing this too
Old Oct 20, 2006 | 12:48 PM
  #39
code4's Avatar
Good, glad you found one. The book is pretty accurate but I prefer removing the pass kick panel to unplug the harness rather than trying to pull it into the engine compartment to disconnect. You'll see what I mean.
Old Oct 21, 2006 | 10:12 AM
  #40
P Mack's Avatar
I have a bunch of pictures from my engine swap. Here are a few of them. If anyone wants them let me know.
