Installing ARP head studs, need a few tips
Old Sep 15, 2006 | 01:48 PM
Tony @ MPH's Avatar
Default Installing ARP head studs, need a few tips
Taking my ARP head studs out of one motor and installing them in a fresh motor. I called ARP regarding lubrication since I don't have their moly lube handy and they said it is fine to use SAE 30 motor oil, the effect and torque values required will be the same.
I tried searching and search is either down or slow... so could someone point me to a thread/url with the proper install procedure? I do have the service manual so I know how factory bolts should be torqued and in what order but I do not know if there is a special procedure required here.
I would imagine the torque values for the stud itself are probably different than the torque values for the nut. Factory service manual calls for two passes of different levels of torque for bolts, does this have to be done to the studs when going in to the block? I would definitely do it for the nuts since that seems like it can only help gasket seal.
Thanks for any pointers.
Old Sep 15, 2006 | 03:03 PM
Black Z/28's Avatar
Here's the install instructions I got with mine:
Old Sep 15, 2006 | 04:12 PM
CLOKWRK's Avatar
I was told the studs themselves should go in dry... and only hand tight. Then the heads are torqued down in 3 steps for the large nuts, 25/55/75ft.lbs. if I remember correctly. Let it sit overnight (at least) and check/re-torque all nuts. This was with the ARP moly lube though...not sure about 30w specs?
Old Sep 15, 2006 | 04:40 PM
Tony @ MPH's Avatar
Awesome!! Thanks Black Z28. This is a fresh motor and I think the bolt holes are clean/clear. I'll use an old bolt nicked up as a chaser if necessary. Otherwise that sounds like a very straightforward install procedure.
Thanks again!
Old Sep 16, 2006 | 01:13 AM
silverZ98's Avatar
when i called last week they told me to use the arp moly lube on the studs in the block and the nuts, all so to go 30-50-70 with there lube and 85 with oil.
Old Sep 16, 2006 | 08:30 AM
MiaSSmaro98's Avatar
so the studs only go hand tight into the block?
Old Sep 18, 2006 | 01:53 AM
prplhaz's Avatar
Yep, only hand tight! Theoretically you just need to have all the threads of the stud fully engaged for proper function. Once fully seated and hand tight they aren't going anywhere....
Old Sep 18, 2006 | 05:50 AM
PREDATOR-Z's Avatar
Moly lube needed. rest is as per instructions
Old Sep 18, 2006 | 12:08 PM
so wats the deal with the option of a hex nut or a 12 pt?
Old Sep 27, 2006 | 02:44 PM
Studytime's Avatar
Are there more people out there that can confirm the heads slip on/off easily with head studs and the motor in the car?
Thanks.
Ben T.
Old Sep 27, 2006 | 02:47 PM
Black Z/28's Avatar
Here's some confirmation for you:
https://ls1tech.com/forums/generation-iii-internal-engine/558010-arp-head-studs.html
Old Sep 27, 2006 | 02:51 PM
Studytime's Avatar
Thanks Black Z/28. That answered my question well. And let me just add, that's a hot h/c package you have for such a small intake lobe. 395 on a mustang dyno is nothing to sneeze at!
Ben T.
Old Sep 27, 2006 | 05:15 PM
Black Z/28's Avatar
Ben T.
Thanks. I thought the numbers were pretty good for that 'puny' cam. I'll give credit to the heads (and the additional work I did on them before installing them).
-Jay
