patriot heads, are they worth it
I ordered stg 3's but my flow sheet (provided by patriot) showed slightly lower cfm numbers than advertised....as well as different valve size than advertised.
Weird I know, but the numbers still looked good for a thousand bucks!
I love them for the little bit of driving on them the work great so far. I had no issues putting them on everything bolted up just fine. I saw no bemlishes or anything. I agree for the thicker deck and what not but there are people pushing 600+ with stock 317 heads now. I have the stg 3 6.0 heads 208 160 And luvem!
I love them for the little bit of driving on them the work great so far. I had no issues putting them on everything bolted up just fine. I saw no bemlishes or anything. I agree for the thicker deck and what not but there are people pushing 600+ with stock 317 heads now. I have the stg 3 6.0 heads 208 160 And luvem!2.055 int
1.57 ex
Now that I look at it I guess it is pretty damn close. I thought they were further off. Oops. DO they use a pipe to flow their heads?
As far as flow...advertised:
int @ .550 = 310 (Actual 299.6)
ex @ .550 = 233 (Actual 223.8)
int @ .600 = 320 (Actual 307.1)
ex @ .600 = 236 (Actual 229.2)
if you've got anymore questions, call Jason at J&J Speedshop 716-830-0506
The Patriot Gold valve springs are awsome though..... they speced out higher side by side then the comp 921's i was going to use.
Thats my .02
Kyle
Thats my .02
Kyle
The numbers being lower is because the advertised numbers on our website for the stage III were taken using a 4.125" bore. The numbers for your heads were flowed on a 4.030" bore to closer represent how they will perform on your specific application.
As to your flow saying 2.055"/1.57", this operator on this test simply overlooked changing the specs. All of our heads are flowed, vaccum tested, and pressure checked before leaving our shop. Our heads are of high quality and are availabe at a great price. The products we use to build our heads are the best on the market, Ferrea valves, Patriot Gold springs, brown viton seals, machined spring bases, Super 7 machined locks, ti retainers....only the best. The valves are hand lapped and each head is assembled by our shop foreman who has 15+ years of experience.
I take it that wasnt the same almost 2 years ago when Terry was there............
If all above it true now thats fine...... really it doesnt matter who's heads they are always have a once over with them before they go on the car.
Kyle
great guy to deal with, thanks gunnar
Kyle
Thats BS comment!The work at Patriot is performed the way the owner wants it done,not how I wanted it to be done.I wasn't in charge,I just worked there.It wasn't my decision on what brand parts to use.I didn't perform the assembly,I was just the contact on LS1tech.The work that was performed at Patriot when I was there is performed the same way as it is now.The only difference is now they use better quality valves,and I agree the person assembling the heads is better than the workers that used to be there.When you have better people in the shop and use better quality parts you can produce a better product.
2.055 int
1.57 ex
Im not sure how they flow their heads and my sheet showed flow with 208 160
Hummm..
Ill agree with ya there... wasnt pointing the finger at you... was using you as reference in a timeline...
Kyle
I like my patriot heads other then that. i made 421hp at the wheels with my cam, and now i need bigger injectors. plenty more power on tap. damn bastard year '98
No comment!
