heads/cam setup!?!
Old Sep 18, 2006 | 08:30 AM
NVR KNO's Avatar
Default heads/cam setup!?!
hey guys. i am wanting to go with a heads/cam setup and i just dont know which would be the best? i am looking for around 480-490rwhp. is that even possible with just heads/cam? i have lt headers/cutouts/lid/tune and with the cutouts closed i was able to get 352hp/360/tq. now im ordering the gmmg catback and a new qtp y-pipe with the electric cutouts on it. if i were to get a big cam like the ms4 or trex and a good set of flowing heads and an aggressive tune, do you think i could achieve my goal? if not, what else would i need? any help would be good. thanx.
Old Sep 18, 2006 | 12:24 PM
allngn_c5's Avatar
HUGE cam with lots of duration. You can see what my setup did 473rwhp 431 rwtq, using afr 205's milled to 59 cc and the G5X3 cam with a FAST 78 mm intake and all bolt ons. Plus Meziere ewp, and ASP ud pully.
I probably would've saw close to 500 rwhp with the G5X4 and a ported 90 mm FAST and a 90 mm TB.
Good luck bro.
Old Sep 18, 2006 | 12:48 PM
ArrestMeRed99Z28's Avatar
I personally like Patrick G's setup, AFR 225 small bores, 224/228 on 110(?) LSA on LSK lobes, with ported 90 90 setup. I believe he put down 475hp 430tq, and only 6 degrees of overlap so it doesn't sound like a huge cam, good for street racing
Old Sep 18, 2006 | 01:22 PM
NVR KNO's Avatar
Good luck bro.
thanks for the advice guys. i am planning to go with the ms4 or something like that. would this be comparable to the g5x4? i also like the afr 225's. if i were to port my ls1 intake would that be as efficient as a FAST 78 or 90? does the meziere ewp help that much with power?
Old Sep 18, 2006 | 02:17 PM
LS1IMPULSE's Avatar
500HP seems like a lot for what im am pressuming is a stokc shortblock? I know most people have been saying that 550 is about the limit for the stock LS! stock block.
Also Patrick G has a built Thunder Racing 347 Shortblock.
Old Sep 18, 2006 | 04:41 PM
NVR KNO's Avatar
well i have a friend who has a sts turbo kit and his car made 478whp with only the turbo kit. everything else is stock, stock manifolds, y-pipe, internals, everything. his drives fine. also allngn_c5 has 473whp and his motor isnt messed up yet either. if i make right under 500whp, then i should be fine, hopefully.
