Shortened Rocker Bolts Question
So the ones that stuck down into the intake track I chucked them up in my lathe and took about .040" off. Now they are flush with the top of the intake track. There was no problem with the ones for the exhaust.
You might want to check Manley and the ARP websites as they make quite a variety of studs. I was thinking maybe you could grind them down but you would want to be carefull on the heat. You could also do what I did and find a friendly machine shop if you don't have a lathe.
This process should take you only a few hours, and you're hours of labor might net you 1 rwhp.
