just some basic questions hopin for some answers
Old Sep 19, 2006 | 03:39 AM
z28maroman's Avatar
Question just some basic questions hopin for some answers
just wondering....does anyone recommend pcv removal and adding breathers? why or why not....also i am planning on taking EGR off of my car for a ls6 intake and some off road headers...this is definatly ok right? Also looking to get rid of that annoying whine and useless 3 miles of tubing by removing the A.I.R any comments on this? i am keeping this car as my daily driver, so i want to make sure i can do this withought killing my car. the only reason i want to remove pcv is to stop oil consumption and getting oil into everything and clogging it. Please inform me i am new to the ls1 motor so im not positive on what to do....thanks guys
Old Sep 19, 2006 | 04:02 AM
DaddySS's Avatar
PCV - there are differing opinions on how much of the "oil reversion" seen in the LS1 intake is from the PCV. I personally recoomend a catch can - you'll trap the oil but keep some vacuum in the engine which is better for keeping the pressure down, helps reduce oil seepage, better for the atmosphere and your car will smell less!
EGR - OK to remove
AIR is only there to make the cats work better sooner. If you remove the cats then it has no purpose.
You will need to get a tune, which you will want to do anyway, to remove the codes and mils for the EGR and AIR.
If your state has visual inspection or a sniffer test, none of these will pass so be sure to check that.
Old Sep 19, 2006 | 08:08 AM
GuitsBoy's Avatar
Switch over to the LS6 PCV and run an ebay catch can for cheap. Breathers greatly cut down your oil life becuase the fumes and contaminants are not evacuated and reburnt.
Old Sep 19, 2006 | 12:17 PM
z28maroman's Avatar
ok thanks. what is the difference in the ls6 pcv and the ls1? i have no emissions where i live luckily so i am doing all off road exhaust so i will have no cats to worry about.
Old Sep 20, 2006 | 12:07 AM
z28maroman's Avatar
Also do you reccomend removing my A/C will this create any more power at all?
Old Sep 20, 2006 | 07:52 AM
GuitsBoy's Avatar
No, but it will remove considerable weight off the front of the car. Probably not worth it unless youve got a fairly serious race car.
Old Sep 20, 2006 | 08:37 AM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
Good call. I would only run a breather or crankcase evac on a "race car".
Old Sep 21, 2006 | 01:55 AM
z28maroman's Avatar
ok thanks alot guys...i will be getting my lt headers y pipe and cut off in a few days here. I was just wondering, i removed the egr and the air pump and now it smokes like crazy is this normal??? i put block off plate on everything and used a freeze plug in the manifold i beleive i did it all right now im just nervous about the smoke
