Fuel pump problems PLEASE HELP
Old Sep 23, 2006 | 09:29 PM
ArcticZ28's Avatar
Are you sure it has to do with the test light being connected or could it be that pin has a faulty connection that is fixed when you are pressing on/around it? Just trying to think of things here as that doesn't make much sense to me at the moment
Old Sep 23, 2006 | 09:46 PM
ls1_doc's Avatar
No cause all we have to do is probe it once and then it is completly fine until we swap computers. I was wondering if in some kind of lo tech way it reflashes it ? Anyways we are fininshing putting some stuff together right now and we will go drive it and see how it does.
Old Sep 23, 2006 | 10:54 PM
ArcticZ28's Avatar
I guess sometimes you just shouldn't question things. Good luck. Let us know how it goes.
Old Sep 24, 2006 | 02:21 AM
ls1_doc's Avatar
Ha well bad news. I can get it to run no problem BUT the kicker is the computer is hot. Like u put a test on the case and lights up. When we pull the 50 amp fuse for ign in the fuse block it goes away. Any more ideas ?
Old Sep 24, 2006 | 02:00 PM
ls1_doc's Avatar
ttt please
