Cam clearance question: interesting test of theory
Old Sep 22, 2006 | 11:32 PM
N4cer's Avatar
Default Cam clearance question: interesting test of theory
All you guys who know cams so well:
Everyone says duration hurts PTV clearance... not lift. That has me thinking. I have clearance on this setup that is close. Around 0.050" PTV on the intake side. So let's say that instead of flycutting or changing heads (one of which I'll probably do but let's ignore it for theory's sake), I change to a cam with better exhaust duration and more lift on intake and exhaust. Would that still clear?
I mean, say I went with a cam more like Patrick G's
224/228 .637/.639 110LSA only change it to a 112 or 114+2 LSA?
would I have any issues?
Let's see how this theory pans out.
Old Sep 23, 2006 | 12:05 AM
ShevrolayZ28's Avatar
Here's a great tutorial on valve timing.
http://www.compcams.com/information/tutorials/
Max lift happens when the piston is way down low.
Old Sep 23, 2006 | 12:28 AM
redtail2426's Avatar
depends on how aggresive the lobes are,if they are more aggressive,then you will still lose clearance,and chances are if your adding more lift and keeping the same duration,then its probably a more aggressive lobe,but some customizing could be done i guess.
Old Sep 23, 2006 | 09:21 AM
Patrick G's Avatar
LS1 Tech Administrator
A cam with faster lift off the seat (like an XE-R lobed cam) will help tighten up your p to v clearance, but only a degree or two. Widening the LSA helps because you shorten the overlap cycle, but often that hurts overall performance.
FYI, LSK lobes are not as fast off the seat as XE-R lobes:
49 degrees (.006-.050") for XE-R
50 degrees (.006-.050") for LSK
LSKs are your best choice for p to v help. Solid roller would be better. Now THAT's faster.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 23, 2006 | 11:47 AM
I didn't know that. I guess the LSK lobes must have a really fast ramp rate thereafter.
Old Sep 23, 2006 | 01:10 PM
yeah i thought the lsk lobes would give you less clearance,this is new and good info to me and im sure lots of other people
Old Sep 23, 2006 | 01:11 PM
N4cer's Avatar
No, I PM'ed Patrick G to get clarity. He's saying that the PTV clearance is even less with the LSKs. So I'm better with my XE-R lobes due to the faster initial ramp rates.
Old Sep 23, 2006 | 06:03 PM
okay thats good because i really thought i was going crazzy..
