Torquer V2 Question
Old Sep 23, 2006 | 12:09 PM
BrianC98Z28's Avatar
Default Torquer V2 Question
What springs are yall that have this cam using? Can you use 918s or did you use the dual springs for it? The V2 is a .595 .598. Just wanted some info on it.
Old Sep 23, 2006 | 12:57 PM
Joey7489's Avatar
The comp 918's are limited at .600 lift which means your .5/.2 away from the limit. I would go with some PRC double springs. Theyre limited at .660, so you have plenty of lift left over there and theyll last much longer.
Old Sep 23, 2006 | 01:54 PM
nukeemall454's Avatar
yeah thats what i figured i want there 231 237 cam pretty soon and i figure ill go with double spring for a little extra peace of mind
Old Sep 23, 2006 | 02:05 PM
iamsickofitall's Avatar
PRC duals here...wouldn't go with a single spring with this cam
Old Sep 23, 2006 | 02:32 PM
RoastEmSS's Avatar
same here
