how deep is the Valve Relief?
Old Sep 26, 2006 | 12:57 PM
PREDATOR-Z's Avatar
Default how deep is the Valve Relief?
How deep would 2.2 cc valve relief be?
I forgot to measure mine
Old Sep 27, 2006 | 12:20 AM
PREDATOR-Z's Avatar
Ok, how deep is 2 cc ??
Old Sep 27, 2006 | 04:36 AM
cantdrv65's Avatar
Post
Do you have access to the cutter you used? Just measure the dimensions of the cutter then calculate volume. Adjust your dimensions until you come up with 2cc volume. Walla, there is the correct depth.
Old Sep 27, 2006 | 06:46 AM
PREDATOR-Z's Avatar
I didn't cut, those are forged Wiseco pistons.
Motor is allready all buttoned up and running.
I might be looking at some outrageous cam and knowing the depth of those reliefs would help in choosing the VEs and chamber size of new heads.
Old Sep 27, 2006 | 08:03 AM
GuitsBoy's Avatar
Do you know the free drop of the heads? You could go to TDC and measure the free valve drop minus gasket thickness minus the original free drop.
Old Sep 28, 2006 | 01:53 AM
PREDATOR-Z's Avatar
I e-mailed Bryan Neele at LME. He should know. He built the ironmasterthingy
Old Sep 28, 2006 | 02:38 PM
DanZ28's Avatar
2 CC's should equal to 0.1220".
Dan
Old Sep 28, 2006 | 03:24 PM
ty_ty13's Avatar
7 Second Club
it all depends on how wide a cut you made and how deep...
Old Sep 28, 2006 | 03:39 PM
DanZ28's Avatar
Figure about .061" per CC.
