Changed oil...is this trouble?
This was on my drain plug. Not sure if this is anything but thought I'd ask more knowledgable people.
Is the engine making noise, other than the oil leak do you have any reason to believe something is wrong?
The oil may be coming from the pulley seal and that's an easy replace.
Start with the basics - clean up all of the oil, check around the front of the engine to find the source.
Tell us about the car - how many miles since the mods, when did you get it, how many miles?
2. Car has 40,5xx miles. I've had it since Feb. 03 and the last mod was the cam which was last October.
There should not be "normal" metal shavings when you change oil.Metal shavings: BAD
No Metal shavings: GOOD
The trash you see on you pan and front cover is road debris which you're going to get rid of when you do the gunk job and change the def. gasket or seal, right? If you have metal shavings floating around on the INSIDE of you motor the old cliche applies: Pay me now or pay me later.
Pay now: GOOD
Pay later: BAD
sloppy oil pouring? leaknig oring seal on the filler neck? weeping valve covers?
FREE UNDERCOATING - well not free but you are going to throw it away anyhow...
I think a leaking front seal would be blowing alot of oil, 2 quarts per 1000 miles - and it gets worse the longer it goes until it blows. watch that oil pressure gauge. Another point -- does it appear to be leaking under pressure OR while parked/off? If mainly when it's off then maybe it's synthetic weeping -- might try the oil "cleaner" stuff -- see other synth threads. if mainly when driving then look at front seals and the like. Did you re-use the front seal when you changed the cam? did the seal lip get sucked backwards or damaged when putting the cover back on? it could take a few months to wipe out a front seal installed improperly (or maybe it just failed). Those could be parts of the inner spring for the seal? is the cam "walking" to the front and back -- should have been a shim on that one. did you install a new chain set with the cam -- is it grinding the case (malleable aluminum pot metal chards)? Think about that cam install and how easily it all went back together. I admit I've pulled more than one back apart to fix botched seal job. The hardest one to figure was when we used the tacky-gasket junk on the front case cover and the gasket shifted/rolled during installation. When running the engine sprayed a minute stream of oil out the cover edge. The strange thing that it appeared that the fenders were leaking oil when parked, but not all the time. Put cardboard under it for first 20 minutes after running and it cooling down. then switch it and see how much more oil leaks -- is it constant?
I didn't do the cam swap. I had a local shop by the name of Fastech do the work. I couldn't tell you how long it has been leaking or whatever. A lot of the other questions can't be answered yet either since I found this out yesterday and finished up what I started. I'll check it out later today.
Yes, they were stuck on the magnet. Also it looks like the oil seapage is from the front of the oil pan. I am also doing a oil analysis on the oil. Anyone know if that will show anything if I do have a problem?
