Is a tune absolutely necessary for this?...
Old Sep 27, 2006 | 04:01 PM
Stroker2112's Avatar
Default Is a tune absolutely necessary for this?...
Guys,
I just replaced a 323ci (5.3L) with a 408ci(6.7L)....the intake/TB,MAF, and everything else (fuel pump, electrical harness, all accessories) are the same.
What's new are the LT headers, 44lb injectors, bigger cam and CNC'c 243 heads. The 408 fired right up, sounds great and idles perfect.
So my appointment with the dyno-shop isn't for another 2 1/2 weeks....so you know what I'm thinking here....
What could I potentially screw up by taking it for a spin to break in the ring seals?...
Stroker2112
Old Sep 27, 2006 | 04:28 PM
doobieboy's Avatar
maybe. That tune isnt setup for those injectors lol I suggest you bite the bullet and wait for the shop to tune that bitch
Old Sep 27, 2006 | 04:34 PM
98 Raptor TA's Avatar
Get it tuned. Of course it may not be "absolutely necessary" cause it may run without a tune, but it wont run PROPERLY. Your a/f will most likely be really off.
Old Sep 27, 2006 | 04:38 PM
OK, so would the larger injectors spray more than the old ones even if the fuel delivery setting is fixed in the PCM?...if so then I understand the a/f will be too rich (but how much richer?...what would happen if someone ran too rich for say....10-20 miles?) I haven't upgraded the fuel pump yet either...
Old Sep 27, 2006 | 05:17 PM
Cop Car's Avatar
if i put 10k into a motor i wouldnt risk it.. even though its really tempting lol
Old Sep 27, 2006 | 06:49 PM
slimcracka's Avatar
you could wash the ring with gas and screw them up..just wait..
Old Sep 27, 2006 | 06:58 PM
thechef's Avatar
Moderator
exactly
Old Sep 27, 2006 | 08:26 PM
If I just heat cycle the engine (idle only) a few times will that do any harm?...
Old Sep 28, 2006 | 08:56 AM
eamador11's Avatar
