Comp R's or Morels?
Old Oct 14, 2006 | 10:20 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mike, you did not like what, were the R's collapsing? I sent you a pm, I am working through some valvetrain issues right now.
Old Oct 24, 2006 | 09:44 AM
2002blackZ's Avatar
does anyone have a picture of the Morel lifter next to an OEM lifter showing the difference?
Thanks
Old Oct 24, 2006 | 10:41 AM
Cstraub's Avatar
Tell tale sign of a Morel is the oil band is inverted from the bottom to the top. The band is also relocated on the body to provide proper oil metering to the the engine.
Old Oct 24, 2006 | 10:52 AM
2002blackZ's Avatar
Thanks. I should have the heads off tonight to check. Just hope the lifter going bad didn't kill my cam....
Old Oct 24, 2006 | 12:14 PM
JG853's Avatar
I have the Comp R's as well and have not had any problems.
Why are the Morels better? Just asking for my own benefit.
JG853
Old Oct 24, 2006 | 01:36 PM
V6 Bird's Avatar
I may end up hydraulic still since the machine shop has just finished their prototype Rev kit for these engines..its very freaking trick and sweet!
Old Oct 25, 2006 | 07:48 AM
Cstraub's Avatar
JG853
Morel was asked by several cam companies to design an aftermarket lifter for this engine platform. Relocation of the oil band was critical because aftermarket core supply for the LS1 engine includes 6 different base circle sizes and depending on the cam profile this could cause oiling issues.
The lifter is 100% USA made it is not a reboxed OEM production piece nor an imported piece.
Tolerances and manufacturing quality allow this lifter to rev higher in the rpms and run longer in the rpms without pumping up. This will result in more power.
The lifter is fully rebuildable. So after the initial purchase you have bought your last set of LS1 lifters.
Old Nov 25, 2006 | 11:34 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
the new gm lifter is alright , i have the new lifter, its the one they run in the ct-v r's, but you have to remember they rev 8000 rpm, but they have ti vlaves, and other very trick valvetrain parts. with stainless valves you are going to be hard pressed to rev it past 7200 rpm.
Old Nov 25, 2006 | 11:49 PM
sidewayz28's Avatar
where can we find these new GM lifters?
Old Nov 26, 2006 | 07:44 AM
speedracer5532's Avatar
https://ls1tech.com/forums/generation-iv-internal-engine/580686-new-upgraded-hydraulic-roller-lifters-sdpc.html
