fly-cut?
Old Sep 29, 2006 | 07:51 AM
6speeder's Avatar
Default fly-cut?
What are the chances I'm going to have to fly-cut when using AFR 225s that are shaved 18 thousandths and a cometic .43 gasket with a 224-231 .577-.588 lift cam?
Old Sep 29, 2006 | 07:56 AM
JRracing's Avatar
Slim chance I would think. But I would ask one of the big boys about it.
Old Sep 29, 2006 | 08:10 AM
6speeder's Avatar
Ok, Thanks for the quick reply. Who would you suggest I ask? Thanks again, Brian
Old Sep 29, 2006 | 09:28 AM
GuitsBoy's Avatar
Youre valves are gonna be almost .030 closer. Its probably going to be tight. Check and be sure about it.
Old Sep 29, 2006 | 12:21 PM
hammertime's Avatar
With the duration numbers on that cam, I would say you are probably safe.
I assume the 225's use bigger valves than stock though, so it pays to physically check it rather than take someone's word for it.
