Stroker question
Old Oct 2, 2006 | 09:49 AM
Supraman's Avatar
Default Stroker question
This may be a stupid question. I am investigating stroking a LS1 engine. Is it possible to use a crank from a 6 liter iron block motor and put it in a LS1 alum. block ?
Old Oct 2, 2006 | 09:50 AM
sroach20's Avatar
same crank 3.622
Old Oct 2, 2006 | 09:53 AM
Supraman's Avatar
Then would I assume that the bore must be larger then.
Old Oct 2, 2006 | 11:46 AM
Steve Bryant's Avatar
LS1 Tech Veteran
Yes, the bore is the difference between the 5.3, 5.7, 6.0 and 6.2 L engines. All use a 3.662" stroke crank. All of the cranks are similar (stroke is the same and bearing journal diameters, etc. are the same). The counterweight design weights are changed for different rotating/reciprocating masses (bobweights) and the reluctor wheels will be either 24X or 58X depending on the engine and year of production.
Steve
