DCR calc. please!
Old Oct 2, 2006 | 02:31 PM
lilbuddy1587's Avatar
Default DCR calc. please!
.006 durations 289/295
.200 durations 164/167
LSA 110+2 ICL 112
Built 383, -4cc pistons, .040 cometic gasket, 62cc heads
thank you!
Old Oct 2, 2006 | 02:52 PM
ringram's Avatar
http://www.kb-silvolite.com/calc.php?action=comp
Old Oct 2, 2006 | 04:20 PM
Thx but bad link.
Old Oct 2, 2006 | 05:30 PM
Bump TTT
Old Oct 2, 2006 | 07:12 PM
oange ss's Avatar
waht size cam advertised ?
Old Oct 2, 2006 | 07:19 PM
Ryan02SS's Avatar
Advertised duration is normally referred to as .006 numbers, they are 289/295. Maybe you mean the .50 numbers.
lilbuddy, what length rod and stroke are you planning. 4" stroke? I need to know before I figure for ya. Also is it a 110 ICL advanced 2 degrees? As above you have it a 112ICL.
Old Oct 2, 2006 | 07:28 PM
oange ss's Avatar
i got 8.7, assumin 6.098 rod, -.008 deck height, and 3.91 for gasket bore...11.85:1 compression
Old Oct 2, 2006 | 07:47 PM
Beast96Z's Avatar
11:8:1 SCR with a 8.9 DCR.
Old Oct 3, 2006 | 12:26 AM
Its a 110lsa with 2 degrees of advance ground in so I assumed 112 ICL. It's a 4" stroke as well. For those that asked, the cam is a 239/246 .649 .614 110+2.
I might just install the cam straight up as 8.9 DCR is pretty scary on 91 octane. I do have a nice tight quench, but still...
Thanks man, I appreciate it! Thanks to everyone who has chimed in.
Old Oct 3, 2006 | 12:34 AM
oange ss's Avatar
woops...8.87 with correct LSA/ICL
Old Oct 3, 2006 | 02:45 AM
If I was to retard the cam and install it @ 110icl and 110 lsa, what would the DCR be?
Old Oct 3, 2006 | 12:13 PM
Ttmft
Old Oct 3, 2006 | 12:29 PM
PREDATOR-Z's Avatar
11.77:1 SCR and 8.82 DCR on the original post
and on a 110+0 (straight up)
11.77 SCR and 8.66 DCR
Old Oct 3, 2006 | 03:18 PM
So 110+2 = 108 ICL then correct? and 110+0 = 110 ICL?
Old Oct 3, 2006 | 05:38 PM
oange ss's Avatar
yes..
