Do I have to flycut??
Old Oct 3, 2006 | 09:58 PM
that240guy's Avatar
Default Do I have to flycut??
do you have to flycut the pistons if you are using stock 241 heads with the TREX or TRAK cam. I am trying to decide which cam to go with and I am trying to make a shopping list of things I need. Which springs are optimal for a cam this big? Will my stock lifters and rockers be ok?
Thanks!
Old Oct 3, 2006 | 10:03 PM
Studytime's Avatar
No flycutting required it was a design requirement by Thunder Racing that they fit in a stock motor. Your lifters and rockers will be fine. The PRC dual springs or even better the Comp 921s would work.
Ben T.
Old Oct 3, 2006 | 10:09 PM
that240guy's Avatar
Thanks Ben!!
Old Oct 3, 2006 | 10:12 PM
BriancWS6's Avatar
Ben T.
He's right, it will fit. But that's not with the textbook .080 intake/ .100 exhaust clearance. But people do it all the time.....
Old Oct 3, 2006 | 10:15 PM
that240guy's Avatar
Do you know where the clearance ends up or if anyone has had piston to valve clearance issues without flycutting?
Old Oct 3, 2006 | 10:25 PM
Studytime's Avatar
I doubt there are any common problems. This camshaft was designed for cam-only setups and to work with a stock motor. The fit is close, but it clears.
Perhaps give Thunder a call?
Ben T.
Old Oct 3, 2006 | 10:28 PM
that240guy's Avatar
Thanks guys. I will give them a call tomorrow.
