NItrous cam??
Old Oct 5, 2006 | 08:34 AM
superfox's Avatar
Default NItrous cam??
hii
i have camaro with full boltons ,auto trans ,3.4,i will Run nitrous soon 100 wet but i dont know what i chose (CAM) my firnd tell me to run this cam ,
FMS Custom Grind Camshaft - 226"/226" .575"/.575" 114LSA - aggressive profile with a 2000-6600 RPM range, fair idle
and
Patriot "Gold" Springs, Titanium Retainers, Machined bases, Super 7 Locks, & Viton Rubber Seals
are this cam Good to run ,
thanx
Old Oct 5, 2006 | 03:25 PM
superfox's Avatar
no one have ansor ?????????????
Old Oct 5, 2006 | 03:41 PM
darrensls1's Avatar
Originally Posted by superfox
hii
3.4? that isn't a 3.4L V6 Camaro is it?
and Patriot "Gold" Springs, Titanium Retainers, Machined bases, Super 7 Locks, & Viton Rubber Seals
thanx
That cam will work fine on a 100 shot. Generally speaking the only thing you want to avoid is spraying big shots on reverse split cams. For example a 230/224 would be a reverse split. Traditional split cams work even better on the spray. An example of that would be 230/236. But the bigger the cam the bigger the torque converter needs to be so keep that in mind.
What size stall are you running now?
Old Oct 5, 2006 | 03:59 PM
superfox's Avatar
stock converter ,3.4 gear
Old Oct 5, 2006 | 04:07 PM
darrensls1's Avatar
Gotcha. Ok then the 226/226 114 will be good. For optimal performance you should still consider a 3000-3500 stall & transmission cooler for the car sometime down the road. You also need to replace the spark plugs with NGT TR55's if you still have stock ones in there. N20 + GM's spark plugs do not play well together.
I don't see why you can't get away with stock injectors and the stock fuel pump for that small a shot. But it might not be a bad idea to read a little in the N20 section.
Good luck.
Old Oct 5, 2006 | 07:40 PM
superfox's Avatar
Good luck.
thanx you , i have NGK TR-6 i order it with the nitrous kit HSW
Old Oct 5, 2006 | 11:10 PM
meatfoam's Avatar
If you are willing to consider something a little more tame, then I can highly recommend the hotcam. Great for retaining driveability, lopes nicely on the 112 LSA, and looves nitrous, loves it!!
Here ya go: Idle video
And a run on street tires, hotcam + 100 shot: clicky here not the fastest 1/4 mile, but look at the trap speed... Hotcam + N2O, a match made in heaven
Whatever you do, get it dyno tuned. It is so sad and frustrating to see people's cars not run to their full potential after all that work, just so they could save a few bucks!
Furthermore you might wanna consider a fuelpump upgrade. Many say that it isn't necessary, but yikes... that can really f* **** up. It's not too expensive and easy to do.
Most people who spray around here run spark plugs that are 1 heat range colder than stock. The TR6 is the most popular one. I run TR55's though, just pulled a degree or two of timing!
Old Oct 5, 2006 | 11:17 PM
lilbuddy1587's Avatar
Any cam with a large enough split will be a great nitrous cam.
Old Oct 5, 2006 | 11:20 PM
meatfoam's Avatar
Well yes. I am just posting up a well known cam profile that people can relate to. Also, I am advertising it's great all round capabilities!
