I blew up my motor!!
It poured out of it.
But... I think it's because I drove the car for about 50 miles with a blown valve cover that was spewing oil all over the engine.
I am going to have it all cleaned and fixed and maybe have the entire block painted to match the car. Maybe even the intake manifold as well.
If you go back to page one... I put up some pictures. Check them out.
I blew apart a piston. I destroyed a head... I havent gotten the othe rhead off yet, so I dont the extent of the damage in that head, if any.
I know the back cylinder is FUBAR'd.
I already have a new set of heads coming to me today. I just need a block. I am going to set my sights on an LS6 block if possible.
Unless I can have my old block honed out to fix that damage. But I know LS1's are famous for not being able to be honed.
We'll see....
He already told me about it.
I also need to use some of my lifters... and since I am decking/milling the heads for a higher compression, I need to buy shorter ARP head studs and different push rods.
What would you suggest?
We'll see....
J/K
J/K
So,.. LS2 shortblock?
Will LS1 heads fit?
Check eBay.
Which would be better? I have LS1 heads from a 98 coming in today.
Oh, and there is no advantage (from what I read) to going LS6 block over an LS1. Some prefer the '99-'02 LS1 blocks. An LS2 is a larger block (364 cid, makes a good 402 stroker).
Also, there are the LQ9 iron blocks (also 364, make good 408 strokers) to investigate.
I see.. thanks for the info. I wont buy the 98 heads. Not to mention the coil brackets wont line up. Plus, I have been talking to a guy who is sending me his 99 heads with only 45k miles. Those 98's had 85k miles and are coming with problems already.
Plus I am only paying $10 more for the 99's. This is going amazingly well for me so far.
If I could only get a block, I would be in business.
Thanks again for the help!!!!!
I know the fuel didnt match up... so i wasnt running a dyno-testable 300+ shot... I was comparing it to what a "dry" shot would be on an open line.
The ZEX solenoid is capable of flowing up to 350-400 shot depending on bottle pressure. But since mine was a wet shot, I didnt get that close. If it was a dry shot... It would been worse over all for me.
It was still a helluva blast. I was running consistant low 15's without the spray on that 118 degree track. I was on horrible street tires that put out tremendous wheel hop. So I babied the launch, floated softly through first.. then punched it into second and through third & still ran a 13.1x. I would say that was at least a 200 rwhp shot.
I also did not have any tuning at all. I was told I didnt need it on a 125 shot.
I'll put to memory on that copper plug suggestion next time.
But, thanks for the input.
