I blew up my motor!!
Call them and ask. Does it really matter that much?
I will post them all for you guys.
I also did not have any tuning at all. I was told I didnt need it on a 125 shot.
QUOTE]
Who told you that you dont need tuning when spraying?
Not only that, but when you spray you sending all this fuel in there, your probably running super rich (or lean, i dont have much experience with N20) but I wouldnt trust the guy that said you can spray 125 shot without tuning...
Tuning isn't necessary with nitrous, but it's safe insurance. Were you on regular 93 pump gas? If you don't have alot of dough to blow, I'd recommend adding some cheap insurance to the mix. Try to spray with 100 octane. Couple bucks might have just saved that motor. I hit my stone stock LS1 with 225 several times (dual stage dry no jet, NX MAF kit jetted at 75). Tuning and good gas kept the engine alive.
James.. PM sent.
I should have a lot more pictures toomoorw.. I should have it on a lift and the engine out by this weekend.
QUOTE]
I was told I didnt have to retard the timing on a 125 shot.
I knew I needed a tune. I also think I was running rich. It backfired a lot and I had horrible gas mileage.
I am going to do it correctly this time.
Any help on that? I need one cheap as hell and preferrably with heads.. or a bare block and then heads seperate.
Thanks, everyone.
I didnt even know we had that as part of our site.
Thanks again.
