Test drove a 01SS today have some questions.
Also i'm pretty sure depending on how you "broke your car in" can have alot to do w/ the performance aspect. My car was an animal stock leaving me to believe it was broke in properly; i.e getting on it really hard out of the factory.
I think you guys keep neglecting the obvious! The SS has a loudmouth on it...LOWER backpressure often means LESS torque!!! That is probably why the WS6 "felt" faster than the SS. Everything thinks adding high flow exhaust increases power...but if the rest of the motor is stock, you'll often LOSE tq and hp.
I put longtubes on my 1997 C5 and its slower now than it was with stock manifolds. I have new heads and cam on the way so I'll be better after that...but keep in mind that less backpressure isn't always a good thing.
Originally Posted by Billdog350
IEverything thinks adding high flow exhaust increases power...but if the rest of the motor is stock, you'll often LOSE tq and hp.
